tortuga_rc
I am evaluating the crazy idea to buy a Kraton EXB roller chassis and temporarily install there the parts from my old cheap RC car, for a few months.
Can someone help me to figure out if it would even be possible?
These are the parts:
ESC: Hobbywing SC8 RTR
25 kg metal servo
Dumbo RC X6 Gyro Receiver
Motor: KV: 4370 Watts: 550 Max Voltage: 2S Max Current: 46A Max RPM: 50,000 Length: 50mm Outer Diameter (w/fins): 35.8mm Weight: 168g Shaft Diameter: 3.17mm Turns: 9T Rotor (Pole): 2-pole Stator Length: 25mm (motor supports 3s)
The diameter of the EXB pinion is 5mm, so I would need to use my 3.17 mm smaller pinion, would it work ?
New 3S Battery I would purchase separately.
25 kg metal servo
