Time to play…
View attachment 219365View attachment 219366
I “eyeballed” the first one… Less than ideal considering I’m at the mercy of my Dremel, and not my Milwaukee due to the OD of the bit.. This requires that I start the Dremel, then “live plunge” into the piston… I typically have a good eye for this stuff, but with the tool in rotation BEFORE contacting my work-I made some marks.. Not a big deal, and the silicone doesn’t care one bit, either way.. My OCD does though..
View attachment 219367View attachment 219368
The OG setup is (2) 1.5mm. I’m adding (2) 1.1mm to allow for a slightly heavier oil, better low speed dampening, as well as higher HIGH speed dampening by manipulating the “pack” via piston thickness, surface area, chamber volume, and viscosity. We are fairly limited by the design of off-road RC shocks, but that’s not to say we cannot optimize what we have to work with. I decided NOT to run the uber-swanky Fioroni aluminum “dual action” pistons. I’m not super convinced they’ll be much advantage over what I’m doing here, but will absolutely do some testing with them in the future, after I dial in THIS setup. Just a very MINIMAL chamfer here. Really defeats the purpose if you go too far. Realistically-I just want to clean up the trash, and NOT remove more material.
View attachment 219369View attachment 219370
Set my “spares” off to the side, as I’ve chosen what I feel to be the best parts for the builds. Everything is cleaned up, inspected, and modified to my liking. The 72hr Naphtha bath did a stellar job, as usual..
View attachment 219371View attachment 219372View attachment 219373View attachment 219374
I’ve got a few more speshulll trinkets coming for these, but aside from that-they’re ready for me to begin the build(s).. I’ve been doing a LOT of homework on spring selection-and believe I’m extremely close to where I’m aiming to be.
Again-I could not have done this without my boy
@SoCalTazer coming through CLUTCH, as he’s known for.. SOLID daammiit brother of another mother..
As soon as the rest of my stuff arrives, it’s ON. -and I can’t WAIT.
