- In my recliner
- Flying
I spent a lot of time today, trying to get someone's used but newly purchased Tmaxx running right. I need to know what the symptoms are of an air leak, since I haven't encountered that problem in the past. I end up tuning almost everyone's engines at the local track, so I already know it's not a tuning issue with the carb.
I have it idling well, LSN has been set right as far as bottom end and idle temp. The HSN has also been set.
The car starts quickly, idles well, keeps idling without stalling, holds it's idle temp at 195, doesn't go over 250 at WOT. It has the ACNCM head on it.
Everything should be fine.
Okay, here's the problem......it will make one WOT pass just fine. On the next pass it will cough at WOT, and stall if I don't get off throttle. If I richen it or lean it slightly, it will still do the same thing. Sometimes it will return to normal idle, and sometimes it will chatter the clutch and take about 30 seconds to idle down. All the linkages have been adjusted properly, and the barrel doesn't move whether it's idling high, or whether it's idling normal.
So, there's the same type of problem both on the low end and the high. Other than this, when it runs, it's ripping, and I can not account for why it's being this finnicky.
Any suggestions? I haven't run into this problem before. Is this an air leak in the carb throat or backplate?
