Affordable lipo 4s charger & 4s 5000mah 50c bsttery on amazon
Jub
Hey guys I'm planning to get a 1/10 kraton 4S can you recommend me an affordable 4s battery of atleast 5000mah 50C with ec5 connectors as well as an affordable charger for it. I will only have one battery so i just need a single simple charger and i dont mind if it takes a while to charge i only have 1 battery anyway and will probably just use it 3x a week. I appreciate any help i can get here.
Why just amazon?
This is a tried and true charger, low wattage though, so won't charge a 4S 5000 at 1C as you need at least 75W for that, but will still charge it:
$50.40 - https://www.amazon.com/Genuine-Professional-Battery-Balance-Discharger/dp/B0722NGPBS
I would go with at least a 100w charger though, then you can charge at 1C:
$77.69 - https://www.amazon.com/Hitec-RCD-Single-Channel-Charger/dp/B0758FGPQX
I have HRB 3S 5000 packs and they seem to work ok. I'd assume the 4S would as well:
$56 - https://www.amazon.com/HRB-Battery-Connector-Quadcopter-Airplane/dp/B07CYRTBQY
Sorry, just noticed you said 4s kraton... may need a short pack for that.
EDIT:
Nope, looks like that pack will fit per the specs from arrma's site:
165x51x48mm
That HRB I linked to is:
155 mm ×48mm ×32mm
Why just amazon?
EDIT:
165x51x48mm
155 mm ×48mm ×32mm
Wow awesome reply sorry for reading it late
