5 tanks in, now how do i tune it right
temp gun is your best bet.
But at WOT you want a nice stream of smoke.
Go from stand still to WOT. if you bog you could be lean or rich.
Does it cut out at WOT?
what is wot
never mind it blogs when its at full throttle thats only bcuz i broke it in really rich for plenty of lube n no it dont die
nitrostar .15? do 1 half turn lean from factory setting, check temp should be around 230 thats a good tune for that engine
if its still abit low on temps do 1/4 turns till in the 230ish range maby a tad higher. mine is running tip top now at 1.5 turns lean from factory at 235f and its about 40f-50fish outside.
