ImBored
- Thread starter
- #21
Yes it is this oneFor bearings if you want to use grease Racetec Speed Cream is what I use in bigger bearings. In smaller bearings or any bearings that are gonna turn at really high RPMs like motor bearings I use something like Acer Sin Lube. If you use grease you should only pack one half of the bearing and let the grease spread around inside. If you pack it full like you would a car bearing it wont spin very freely and will generate too much excess heat.
I've never used the basic traxxas charger and I havent ran on NiMh packs since the 80s but 4A on a 3000mAh NiMH packs sounds too high. Which Traxxas Charger are you using? Is it this one?
