- Binghamton, New York
- Crawling
- Thread starter
- #21
Update***
M2C rear motor brace, GDS 24T mod 1.5 pinion gear, 3D printed cush drive, and GPM shock sleeves all installed (no pic of the GPM sleeves..yet). Found 1 rear lower shock rod pretty much welded itself to the ball end. Luckily I had a replacement stashed away.
Also, the GDS pinion gear lines up PERFECT with Spur gear. (Found the solution for the M2C motor mount)
Still need to install Perfect Pass Monster T servo, center driveshaft basher block, GPM chassis plate/brace, hot racing aluminum front upper chassis brace, hot racing spur cover, and aluminum wheel hex hubs. The list doesn’t seem to get any smaller on these updates but they’re getting easier
. This week is the week for completion
To be continued…
To be continued…
