WPL C14 - Old Project Back From the Storage Bin
Thank you. I have a couple more orojects to tackle then I am putting this all together. The new 3d printed frame rails are done. Just need to print a new electronics tray and assemble everything now.
That sounds awesome, wish I was proficient enough with computers to use a 3D printer I’d be forever making stuff!!!
Anyone can use them. It does have a slight learning curve, but there are idiots running 3d printers. I mean complete morons. There is software out there that is super simple to model stuff up, and the program that turns the model into a printer program is pretty easy to setup.
I’m a gears and oil kind of person, I may look into it one day but for now I will stick to being a grease monkey bud haha 😂
Been awhile since I updated this. Last up was printing some custom frame rails and painting them to match the body. I finally got the paint work done, and reprinted a new electronics tray and servo brackets. Here are the assembly pics so far.
Servo is mounted in a little more optimized location I think 😉
This is the rear bumper I printed awhile back.
And I repainted the roll cage black. I will probably end up painting the electronics tray and rear bumper to match.
So after all the redesigns and 3d printing and aftermarket parts, the only thing left WPL on this will be the body 🤣
All 3d printed parts...
Prolly much higher quality now :)
Things fit better, that's for sure. I went ahead and ordered some aluminum wheels, which should be here in a few days. They just left Los Angelas.
Looking forward to see this thing completed and running. Still loving that color scheme!
I ordered these wheels a few weeks ago, then decided to add the black. Kinda wish I had ordered black wheels now.
I ordered these wheels a few weeks ago, then decided to add the black. Kinda wwish I had ordered black wheels now.
While I like black wheels on 1:1 vehicles, I personally like white or silver on rc.
Never fails! :doh:
I am just letting my OCD get the better of me. I could use the 16mm screws, but they would either be hanging out inside the chassis, or I would have to cut and grind 8 of them down. Just too lazy to do that.
I'm a big fan of doing it right. :)
Wow!! man that looks awesome.. that printer blows my mind every time. That you show a printed part you did..well done sir👍👍.. I'm also a big fan of do it right the first time.. and then there's nothing to worry about later.. cutting the screws really doesn't take much effort use dremel or just grind down 😉🤣.. with the wheels you could always paint the inside lip. And the center circle. So it matches the body paint and pop.. sorry I tried I can't color on tablets or phones 🤣🤣🤣
Wow!! man that looks awesome.. that printer blows my mind every time. That you show a printed part you did..well done sir👍👍.. I'm also a big fan of do it right the first time.. and then there's nothing to worry about later.. cutting the screws really doesn't take much effort use dremel or just grind down 😉🤣.. with the wheels you could always paint the inside lip. And the center circle. So it matches the body paint and pop.. sorry I tried I can't color on tablets or phones 🤣🤣🤣View attachment 131727
I think the wheels will look ok silver. If not I will try that 😉
So to recap the frustrations with this build...
This is like the 6th time I have tried to mount the axles and links in this truck. Initially I had the stock WPL axles installed, but I wanted a wider track width. I could have just made some hub extenders, but the scrub steer would have been a biyatch on this with these sticky tires. So I ordered MN D90 axles which are like 14mm wider. Then I discovered I needed MN D90 link mounts for the axles. After ordering some I found there was a different set I liked a lot better. After those arrived I found out the WPL aftermarket links wouldn't work, so I odered some MN links. Then the holes in the frame rails were too sloppy, so I printed new rails. I printed them a bit thicker to be sturdier, so now my bolts are too short. Everything is perfect now, so as soon as I get bolts, it is on to the next problem lol.
