- Thread starter
- #941
Hahaha , smart assSo, just curious... how are you doing sticking to that $800 budget so far?![]()
I’m way past my initial price cap. To be honest , I wasn’t sure how much it would hold my interest. Turns out , I’m completely and totally obsessed. My kids too. So glad I found my back to this hobby.Everything RC I've said well this is how much I'll spend or it'll cost---add $200
I have these. As the tips wore, I replaced with better quality TiN coated tips. I've found I need (2) 2.0mm & (2) 2.5mm at times.1.5, 2.0, 2.5, 3.0mm hex drivers & a 7mm & 5.5mm nut driver comes in handy. All M3 nuts are 5.5mm.
Nice. Why do you need two at the same time?I have these. As the tips wore, I replaced with better quality TiN coated tips. I've found I need (2) 2.0mm & (2) 2.5mm at times.
What’s an M3?1.5, 2.0, 2.5, 3.0mm hex drivers & a 7mm & 5.5mm nut driver comes in handy. All M3 nuts are 5.5mm.
Just depends on the stuff I'm working on. Steering or end links. Sometimes just need 2. Some pivot balls require 2 hex drivers at the same time with the screw being installed & sometimes they can be the same. Some applications I've swapped the screws to different sizes.Nice. Why do you need two at the same time?
Off topic? Well, I guess there's a lot behind the scenes when it comes to a "If you had $800 for an electric RC vehicle (any type), what would you get?" thread, because nearly everything has been addressed... almostAwesomeNot to get off topic (too late , I guess
) but you said you haven’t owned anything 10th scale in a long time. Is that because you prefer 8th scale?
Metric nut/screw... 3mmNice. Why do you need two at the same time?
What’s an M3?
Haha , definitely. It’s been an extremely informative thread and I hope it keeps going since I know I will (and do) have many more questions.Off topic? Well, I guess there's a lot behind the scenes when it comes to a "If you had $800 for an electric RC vehicle (any type), what would you get?" thread, because nearly everything has been addressed... almost.
The sceen from 'Oliver' asking for "more" just popped in my head when I read this.Haha , definitely. It’s been an extremely informative thread and I hope it keeps going since I know I will (and do) have many more questions.
M3 screw. 3mm diameter screw. The nut of a M3 screw is a 5.5mm hex, the distance across the flats on a M3 nut is 5.5mm.Nice. Why do you need two at the same time?
What’s an M3?
Some ppl use it for gear grease. Like ring & pinions. I've never used it. I bought some Cow Performance Udder Butter for that. Works good. The lithium grease is really slick tho.And what exactly is white lithium grease used for? Something with the wheels (lube)?
Traxxas uses it as a tranny lube. I stopped using it and use red n tacky or this grape flavored stuff I got. My suggestion scoop or use a grease gun to fill a syringe. Amazon has a variety pack. The smaller can be used for shocks the larger for grease..... leaving your table and items grease free.And what exactly is white lithium grease used for? Something with the wheels (lube)?
I use Tony chacheres blendTraxxas uses it as a tranny lube. I stopped using it and use red n tacky or this grape flavored stuff I got. My suggestion scoop or use a grease gun to fill a syringe. Amazon has a variety pack. The smaller can be used for shocks the larger for grease..... leaving your table and items grease free.![]()
Does it smell when it gets hot or is it when you smell it it's time to change it?
Tastes great is all I’m sayinDoes it smell when it gets hot or is it when you smell it it's time to change it?![]()
The 800 # says it smells good even before it gets to the rear end...Does it smell when it gets hot or is it when you smell it it's time to change it?![]()
