Will it or won't it....
jon2
Nitro ASSpired!!!
Oxnard
Originally posted by joneser4u
dont say a 15fe can't run 45mph,I've seen the 15ss run 70mph on a belt drive,didnt use the vsm, had on of our local pigs clock it!8-0
I just did and I will say it again. THE 15FE WILL NOT DO 45MPH. In stock trim the RTR3 will not do 45mph. Just cause the 15ss may do 70mph does not justify the 15FE to do 45mph. I had the RTR3 with the 15FE and did the same thing and use a cop with a radar gun. the most is did was 37 on stock 2 speed gears and tires
Re: rs4 rtr3= 45 mph
Originally posted by rs43drifter
well i got my rs4 up to 45 now thats one step closer to 60 and all i have added is a 2 speed
You have no proof that car is doing 45 mph dude. I was there with you. Its a stock RTR3 with regular gears in a 2-Speed. When I "see" it clocked at 45 I'll be happy for you but personally I dont think it does 45.
no that I am saying you can't make it happen. Just the way you say you have it just doesn't sound possible. But keep trying man. You can make anything go fast just use facts not assumption. The best tool out there for this is the VSM. it will show the actual speed, Rpm and more. Good luck.:madface:
VSM only shows, mileage, max speed, current speed, and voltage. Nothing more...so it doesn't show the rpm's...
I know I've had some stupid post in the past and I mean stupid post in the past but they were in GC. This post is kinda just out there. :preachin:
sorry got ahead of myself. I stand corrected. Thanks.
jon thinks he knows all,your experiance dosnt mean poop to me,just because you can't get your car up that fast doesn't mean its not possible,maybe you should take into fact,location these engines perform diff. at diff. altitudes,humidity,temp.,and several other factors so before you call someone a liar,you might want to check yourself!:loser: maybe he was going down hill with a temp of 320?
Read again ...you can read right?
Watch who you assume is assuming. ASS. I never said that it wasn't possible. Any IDIOT can make most any Nitro car go hella fast if they gear high enough or just lean their engine out. Yeah location, altitudes, temperature are factors to take account of but that was never stated. NONE OF IT WSA STATED! I went with what he said. I state mine as fact as the car under normal operating temperature is not that fast in stock trim even with a 2 speed installed. The only thing I see from your post is someone that wants to be right because he thinks he is. I owned that car I tried different mills and gearing.
Why don't you back up your post when you want to call a shot. Again the 15SS is made for torque but can easily made to go fast with gearing. When you say belt drive it is already known that a belt drive always has more of a linear power band then that of shaft drive.
well jon, I happen to own both a RTR3 and the 3ss,although I never had the RTR3 clocked with the 15fe,I do believe it has the power with the right exhaust,fuel,air filter,flywheel,ect. to reach his claimed speed with stock gearing! I hate to see someone bashed for a post by someone especially when they say mine wouldnt do it so yours can't! that in itself is a dumba## remark!that has been said to many times on here,why didnt you ask him how he managed to achive that speed rather than call him a liar?Not tring to start shi$ with you just deffending someone who got bashed for no reason! and no i can't read I'm illiterate whats it to you?
How are you figuring this out? Do you have a VSM ( Venom Speed Meter) What calculation are you using? So many people say they go this fast or more and don't know how to figure that out. Let us know as with the stock motor will not get that fast. I am talking about the 15FE.
I am going to entertain this just to defend myself and for the sake of helping others. Saying my car goes this fast has also been said many times and again notmuch to rely on. I ran the rtr 3 against a stock ss and it the ss clearly blows it out of the hole and in the straightaway. I also clocked both mine and the ss with the same radar and the same cop. They may look fast and some would be quick to say "mine goes like 55 I swear!!!"
I don't like getting into arguements.Especially here. If someone calls me a loser and doesn't even talk to me before calling names you automatically are seen by me as a kid. I don't care how old you are or what you have but I have learned that anyone can be immature when it comes to name calling. Hey I was I stooped down to your mentality to call you an ASS.
I like to help as much as I can and if I am wrong I don't mind being corrected at all. All you did was see that I was bashing the original poster. Where in any of my posts did I bash him? I can certainly see where you bashed me! I never bashed the dude. Get it right or don't post at all.
so this isnt bashing?ok?This is a quotw you know!and I do believe you called me an ass before any name throwing went down!yes this is entertaining if it wasn't none of us would be here?
That was fact from two people doing the same thing as the original poster. That post was an anwer to your post prior to that one. I never called you a loser nor did I try to say you will never do it. I simply stated that by you posting that your 15ss can do 70mph does not justify the 15FE will do 45. That is the biggest assumption right there.
You know what this is the most idiotic arguement I have been in quite a while. Go ahead and think what you will if there is anyone reading this that agrees with joneser's analysis of the 15ss can do70 thus the 15fe will do 45 then go ahead!!! I want to post better things up than try to battle with this poster.
Good luck rs43drifter. Regardless of the recent posts in this thread, I believe that you can accomplish a higher top speed . I would really get a VSM to see what changes you do to the RS4 3. See if the change helps you or make you lose some mph. I hope that I didn't offend you like jonesr thinks I did. I was like you saying mine did this until someone asked me to back it up with proof.
no you never said the fe wouldnt do 45?argument over!and yes rs4drifter good luck and congrats on achiving what jon couldnt!
Ok one more time .. The 15FE in the RS4 3 will not do 45 mph in stock trim even with the 2speed. You remind me of the kid who got picked on in school but was waiting to lash out..YOU ARE THAT KID. :flaming: LOL you are no more mature then a 5 year old. My neice has more maturity then you do. She is 9.
You love to read into the post. Yes I did say it won't do 45 IN STOCK TRIM. Do yourself a favor and get your self a VSM then post again. other then that go back to the closet you are in and deal with it.:whack:
I guess that makes you mature?but not right! GOOD ONE! DID YOUR NEICE HELP YOU WITH THAT CUT DOWN?
RLMAO@ Jonesr4u ..and no she can cut you down all by herself.LOL:banana:
:nono: you are just too cool and always right I guess,tell your ol lady I want my boxers back!
For once it wasn't because of me. Choo Choo.
I thought I scaled train wreck would do great for a scaled car site.
Remeber this isn't where we bash the repliers. This is where we are making fun of RS4Drifter, which happens to out weigh me by 60 does, lol.
