Which Nitro Engine Should I Buy??
Register Log in
  • Hong Nor Force .21 (3.5cc) Engine - SG Crank - Slide carb
    Votes: 0 0.0%
  • Fastrax ENDURO Twenty One 3-Port Nitro Engine PS
    Votes: 0 0.0%
  • Total voters
Z.hb71
RCNT Qualifier
Illinois
Bashing
Hey guys,
Can I push this thread conversation slightly beyond its original intent briefly ... starting an engine ... looks like I’ll need a starter box for the TrackStar engine .. how do they work? Is there anything “home made” I can make using my lion drill?
Well a starter box spins the Flywheel directly from under the car, you set the car on the box, line the Flywheel up with the little rubber cog on the starter box, and push down and it will spin the engine over, there are adjustable bump stops so to speak so when you adjust em correctly, when you put ur car onto the box, it will line up automatically with the cog. Heres a vid
That ? should help a bit
RicoBanderez
RCNT Racer
South Cerney
Bashing
Hi everyone,
Well I've heard from Horizon and it's official - I can run a pull start engine provided I use the engine mounts which cost a mere £13.99 so I've about made my mind up.
I'm changing tact and going back to the Hong Nor engine because; to me, having to invest in a starter box just seems like extra faff and not what I really want to do.
The vision I had in my head was turning up at the farm, filling the tank with fuel, pulling the starter and off I go … having a starter box just seems like additional things I have to lug about, additional batteries I have to charge and seems like extra expense in the long run. I may or may not be right.
we'll see eh.
The last thing now I need to figure out is if there's anything else I'll need to buy. Does an engine just connect up or will I need to buy some additional bits?
This is how my engine presentation stacks up now .. I think i'm about done with it for now.
Thanks again for the help guys
cbaker65
Hardcore RCNT User
Kern county ,Calif.
Hi everyone,
we'll see eh.
An xtra glo-plug you would need!
I was just going to say that ,you don't need a fancy engine for just bashing around the house or farm use only!....:hyperbuggy:
Z.hb71
RCNT Qualifier
Illinois
Bashing
Hi everyone,
we'll see eh.
I don't think you'll need anything else. But I would get a couple extra glow plugs!
D3MON
Hardcore RCNT User
Missoula MT
Bashing
to my knowledge, Pilot type cranks are not very commonly used anymore in Big Blocks, i know there are many differences between the 4.0 and the RTR but i would look at what that comes with as far as the flywheel, but it if it does show, would show which type of crank it was designed with in mind. it might even come with flywheel.
you will also need clutchbell, and shoes unless the kit already comes with those.
i am definitely very curious to see how you like that hong nor engine if thats the one you go with.
as far as pull start being preferable, i do agree with this. it is a pain especially when tuning from way off settings and the engine likes to die. have to run back to the starter box or run back and grab the drill to start again.
i did edit this as i didnt clarify well on one of the items.
Thread starter Similar threads Forum Replies Date
N How Many Tanks Should I Put Trough A 4.6 Nitro Engine??? Chassis & Drivetrain 3
G Nitro engine priming and starting difficulties (needs help) Nitro RC 27
J New Nitro engine Nitro RC 10
Rubendb The best 1/10 scale nitro engine Engines 47
Laurent James Nitro RC engine will start but dies when I apply throttle Nitro RC 5
Sledman3064 Ofna nitro engine Nitro RC 13
R JP Eagle R9s old nitro engine - value? Engines 0
SlydeeRC Nitro engine warmer/heater battery Nitro RC 1
G Biggest nitro engine Nitro RC 10
SlydeeRC Preheating nitro engine with heat gun Nitro RC 6
M Need a new clutch for Argus .28 nitro engine Nitro RC 2
Tom14 Will 15% nitro damange my nitro engine? Nitro RC 1
P Nitro engine mounts? Nitro RC 4
P HPI Nitro MT1 engine swap Monster Trucks 6
stevendavis Helpful Nitro Engine Mods Monster Trucks 2
Demonimp Shims in nitro engine Engines 1
Jazzminty trouble tuning my nitro engine Monster Trucks 3
Daniel J My nitro RC engine is stalling Nitro RC 4
Daniel J Nitro engine untouchably hot? Normal? Nitro RC 18
Rickyo007 XTM 28 Nitro Engine Back Plate Nitro RC 6
Lugga What four stroke nitro engine is this? Engines 6
J nitro engine won't work even when I tune it Engines 6
nuka Old Tamiya Nitro Crusher engine swap Engines 5
E Benzin filter for a nitro engine Nitro RC 5
J Nitro XRC engine swap Nitro RC 26
Nxbilyea Nitro engine heat generation Engines 7
S Nitro engine or electric motor Large Scale RC 17
GAJ Nitro engine front bearing, double seal?? Nitro RC 6
B Looking for new nitro engine for RC8 truggy Nitro RC 5
CecilB Nitro Engine/Vehicle Identification Help ? Nitro RC 12
smith1090t Purchased First RC, Traxxas Nitro Rustler w/ .15 Engine Stadium Trucks 17
C Help identifying nitro engine Engines 9
craig911 P shaft nitro engine Nitro RC 8
hamz9561 DOHC V-8 Model Nitro Engine Chassis & Drivetrain 4
B Lrp z.28 nitro engine Traxxas T-Maxx 34
JohnSampson Nitro engine HSN Nitro RC 5
S Picco .21 Nitro RC Engine- Help Wanted (Tuning,idleing) Nitro RC 13
Sweetlou069 How do i find out if nitro engine is new or not ? Nitro RC 12
JohnSampson Nitro 4 Tec Engine Nitro RC 12
Sweetlou069 i need a new nitro engine and i wanted to no Nitro RC 8
M what type of engine on a Traxxas Nitro Stampede? Monster Trucks 17
J New to nitro, engine question Nitro RC 10
B2P hpi nitro star T3.0 engine Nitro RC 14
pjoseph nitro mt without engine? Nitro RC 5
Bruno B Need Help identifying Nitro Engine Nitro RC 2
N .32 Nitro Engine Over Heating Problems Need Help Asap Nitro RC 4
D Fixing my gx 21 nitro engine. Nitro RC 3
dubbiesRcs My nitro engine won't start, please help!! Nitro RC 10
M Duratrax Nitro Evader ST engine inquiry Stadium Trucks 5
B2P Hpi T3.0 nitro star engine problem Nitro RC 1
