I'm using a Spektrum DSX transmitter to fly my Aeroscout. I check the 4 AA batteries each time I fly, for voltage.
My question is when -- at what voltage -- should I replace them, to avoid the transmitter not working fully or losing contact with the plane.
The manual states the following: "Low Battery Alarm: The DXS transmitter will emit a repeating warning tone and the RGB LED will flash red if the AA batteries are below approximately 4.7V." That would mean 1.17 volts per battery. But I would rather not go that low, just in case. But I also don't want to be swapping out batteries when I really don't need to.
For reference, I also have a set of rechargeable AA batteries, and when fully charged, they read 1.3 volts.
Is there a "generally accepted" voltage, for RC flying, at which I should replace the AA batteries?
Thanks
Thanks
