Receiver Battery
PiperCUb
What voltage of a receiver battery pack would you guys recommend for a AR8020T 8ch, something that would be enough to power the servos and data and telemetry from the receiver
Based on the planes you posted, a 6V, 1600mah NiMh pack would probably fit the bill, assuming they're "standard voltage" servos and not 'high' voltage which in this context is a whopping 8.4 volts...
looks like you can run up to 9v on that receiver
I was looking over the servos and on the one that I describing it has Futaba S3003 I think I’m going to go with 7.4v battery if I can find one just so I have enough power , because on the Cessna 152 it has Deluxe Hitec HS-322HD servos and some different ones for the Flaps and Ailerons but I appreciate the response
Good chance that'll fry it, fully charged that puts out 8.4V; 7.4 is the "nominal" voltage when the cells are at 3.7V charge, but that's only 50-ish percent.
Edit: Both servos you described are standard voltage, 7.4v is inadvisable.
