You may be overthinking a bit here.
Your idle game should almost always be 1mm, not sure where you saw .5, if it's not close to 1mm, you probably don't have the LSN right.
Essentially with the LSN, you want it in between the point where it's too lean to start, and where it's too rich and it loads up and won't idle. It's not a huge range in most engines. If your idle gap is 1mm, and it's revving to high, you're probably too lean, and right on the cusp of it being too lean to start up. If it's loading up and stalling when you take off, you're too rich.
What you should do is get the idle gap to 1mm, set both needles to factory settings. Start the engine, and work on the LSN to get the idle good (like I mentioned before, that's usually slightly leaner than the factory setting). Then start tuning the HSN for performance. Once you have that good, you can tweak the LSN a bit if your loading up and stalling, or idling too high.
