what engine would be best for the k2
sounds good, ok dont want to over post. quesiton is what pipe would be good for this buggy too? also what servos would be good and tires?
I would recommend these. I currently run them in my Ofna Hyper 7 Pro PCR...
Hitec HS-645MG Ultra Torque - Steering
Hitec HS-625MG Ultra Speed - Throttle
As far as Tires, you have a huge selection from either Proline, Ofna... It's kinda your preference, & whats better for the kind of track your running on.
For exhaust, I've heard real good things about the OS pipe. I'll try to find the model # for ya... It's big $$ though.
i agree with uDi. the ws711 is a great mill.i have one.very fast and easy to tune....
uDi so you have run this pipe OS T-2050.how is it all around the power band.
low,med,high...
is this the same pipe what udi is running on his buggy? also will this pipe fit the Trinity .21 Sirio Kanai Edition??
ok well here is my list, does it look ok. I have one more question what shock oil should i run with and what diff oils should i run with??? http://www2.towerhobbies.com/cgi-bin/wto0149p god i almost forgot the clutch and flywheel, what would you recommend?? i seen those silding clutches are those any good???
shock oil i use 35wt all around.and add shock spacers as needed.
diff oil iam useing 7k 5k 1k front to rear...
does the flywheel come with the k2 becuase the shoes do?? also what clutch bell should i get?? also what kind of air filter would work on that engine and also what pullstart would work on that engine??
Correct me if I am wrong but I don't think you can put a pull-start on the Sirio engine.
I could be wrong(I have no experience with non-pulls) but I believe you will have to use a starter box with the Sirio.
you need a starter box IMO. pull starts break.and roto starts blow one way bearings. a starter box will not let you down.and if your going to spend 300$or more then get an rb mill...ws711 or the c5..this is IMO
are rb mills anybetter then the siro?? what clutch kit would be good with the k2?
