Chris Pelletier
- Racing
what is the best beginner buggy for carpet racing
thank you for the informationCan't go wrong with a Associated. Either used B6.3/.4, or new B7. If you do go with the B7, I'm not sure what AE is doing about the 5 gear transmission but if it comes with it I would opt for the new 3 gear conversion, 3 gear is better, atleast for stock racing. Parts, support and quality is on point.
Also can't go wrong with Xray, Kyosho, Schumacher, or Yokomo.
Schumacher won the 2wd buggy worlds this year btw
Associated is probably best for the price for the support especially for a beginner. Lots of people run AE. But if the local guys at your track use something different or the hobby shop stocks a different brand, can't go wrong with any brand tbh.
Edit: What I said above is more towards 2WD buggy. 4WD buggy could be a different story. I have a B74.1 (I personally started out with racing with this kit) and it's a beast. Even used B74.2s are still pretty good as well. New new 4WD kits is where stuff gets to get pricey. Especially with the B84 and I heard some people are snapping chassis but Associated is probably working on fixing it currently.
Yeah, the B9.Especially with the B84 and I heard some people are snapping chassis but Associated is probably working on fixing it currently
That would be the new 2wd after the B8.Yeah, the B9.![]()
It will be called "the next AE buggy I'm not buying either."That would be the new 2wd after the B8.
Next 4wd would be either B84.1 or B94.
Confusing![]()
Well it runs 2s as wellIf you are carpet racing, 2s is all that you can use on most tracks.![]()
True. RB10 is a pretty good car. Although with rear motor it might be a handful on carpet. You'd want Mid Motor. it will make it alot easier to drive and more centralized weight and more steering. Although carpet and rear motor is possible, id go with thicker oil in the diff and possibly mod some sway bars on there. Some shock tuning aswell. I'm building a Rustler race project, staying with rear motor for now until I cave in on converting it to Mid. Ill see what I can do to get it driving better. On the lipos, Zeee packs are "ok" for a low powered car that doesn't take that much load. Ok for bashing or just driving around but not really good for racing where you need a consistent pack. SMC and CNHL are my top picks for cheaper/budget brands although really good performance. Only bc cheaper cells like Zeee, the cells just can't handle the load of high powered brushless systems and usually come out of the box with a quite high IR. From my experiences, could just be defects but...Associated RB10? About as beginner as you can get and can probably be modded a little for carpet. I've got one, it runs up to 3s, is RTR, and is simple to work on. The front suspension arms suck but I'm getting upgraded ones
Lots of ppl here buy and sell used RCs that are in fine shape and are super savings compared to new.All the major brands make good buggies, I would see what brands your local track actually stocks parts for. Also what brands are popular at your track. That way you can fix what ever you might break while still at the track. And you can get some setup of advice from others running similar buggies, till you get a better understanding of how changes affects the car. Nothing wrong with getting a used ones, it usually saves you some money. I picked up a used B6.4 last year for $350 with electronics. Let us know what you end up with.
Lots of Factory Team parts too if you want to upgrade itAssociated RB10? About as beginner as you can get and can probably be modded a little for carpet. I've got one, it runs up to 3s, is RTR, and is simple to work on. The front suspension arms suck but I'm getting upgraded ones
Turbo Optima is availible with a Mid option too! Just sayin!I wonder if you can use RB10 parts and transmission and stuff on a B5M chassis to convert it to Mid.![]()
I've been looking for MM kits for my DR10 but no luck. If I can find one then I'd imagine it would have no problem swapping to the RB10. Maybe I'll look at the B5M chassis and seeI wonder if you can use RB10 parts and transmission and stuff on a B5M chassis to convert it to Mid.
But at that point it would be better just to get an actual B5M or a modern mid motor kit on that fact. Or could possibly Dremel and mod the stock RB10 plastic chassis or use one of the SR/DR10M kit chassis.![]()
