If your going to be racing, you going to have to run a .21 mill. I would recommend the Sirio K mill... I've seen it first hand, & it's a beast.... Trinity .21 Sirio Kanai Edition
As far as Tires, you have a huge selection from either Proline, Ofna... It's kinda your preference, & whats better for the kind of track your running on.
For exhaust, I've heard real good things about the OS pipe. I'll try to find the model # for ya... It's big $$ though.
For an engine i'd look at the most common buggy engines - RB WS72 and Nova P5
is your track small, medium, large etc? that's what you want to match your engine to.
and for a pipe, I'd grab an OS T-2050, I think that's what imbroken is talking about.
you'll never buy another pipe again..
ok well here is my list, does it look ok. I have one more question what shock oil should i run with and what diff oils should i run with??? http://www2.towerhobbies.com/cgi-bin/wto0149p god i almost forgot the clutch and flywheel, what would you recommend?? i seen those silding clutches are those any good???
i urge you to look at xtm servos' you can get them super fast, super strong, or in between...for only 35$. price is insanely low compared to other brands.
does the flywheel come with the k2 becuase the shoes do?? also what clutch bell should i get?? also what kind of air filter would work on that engine and also what pullstart would work on that engine??
you need a starter box IMO. pull starts break.and roto starts blow one way bearings. a starter box will not let you down.and if your going to spend 300$or more then get an rb mill...ws711 or the c5..this is IMO
