RetroThutmose
i dont think i've seen this front cantilever suspension on a slash before?
i didnt even know this existed lolNitro Slayer 4x4
But, but, but it has the extended chassis from the 8-time National Champion Revo 3.3 and patented rocker arm suspension.nah, stay under your rock, it wasn't a very good truck.
The very first version was narrow and shorter. After a year or two thry lengthened. Basically a revo in sct skin.i didnt even know this existed lol
need to crawl out from under my rock i guess
i don't acknowledge any Revo wins. it was some stacked deck BS. and as soon as it wasn't it ran away with its tail between its legs. the Revo can suck it!But, but, but it has the extended chassis from the 8-time National Champion Revo 3.3 and patented rocker arm suspension.![]()
It has a number of benefits. It will allow you to basically change the spring rate. The belcrank design and angle of the shock can give your specific rate springs a progressive rate simply by altering the geometry. Initially soft to pregressively firmer.I've never understood the reasoning behind cantilever suspension and I agree with above comments, the revo is a tuuuurd.
Phffffffft!!! Thats what I think. I appreciate the explanation and all but everything you mentioned can be achieved with conventional shocks. Seems like a solution to a problem that doesn't exist. I also strongly doubt that cantilever susp. can react faster than conventional. And regardless of how their mounted, you'll always have more weight up top than with conventional. Id need to see some hard evidence to prove any benefits to it.It has a number of benefits. It will allow you to basically change the spring rate. The belcrank design and angle of the shock can give your specific rate springs a progressive rate simply by altering the geometry. Initially soft to pregressively firmer.
It also converts the shocks from unsprung weight to sprung weight. You're a lot better off having less sprung weight on a car that needs to have the suspension reacting quickly.
You can also mount the shocks low to lower COG.
In racing, it has a lot more benefits. Aerodynamics for example because the shocks and springs are mounted under the body. Mid engine supercars use it. Various offroad racing vehicles use it. It's not just for added complexity.Phffffffft!!! Thats what I think. I appreciate the explanation and all but everything you mentioned can be achieved with conventional shocks. Seems like a solution to a problem that doesn't exist. I also strongly doubt that cantilever susp. can react faster than conventional. And regardless of how their mounted, you'll always have more weight up top than with conventional. Id need to see some hard evidence to prove any benefits to it.
I could do that if I get time. It's something I really was interested in about 7 years ago. But I have so many damn irons in the fire at the moment I'm getting frustrated when I start working on something and end up down another rabbit hole.You should start a thread and convince me...
