I got my Arrma Vendetta last week but have not had a chance to run it yet except in the driveway. Everything seems to be working as designed, but I'll know more when I get it out in a big parking lot later this week.
In the meantime, I decided to address a couple of issues for ease of use and future options.
First off, replaced the humongous body clips with some thinner ones. Much easier to work with.
Next was the 14mm hex wheel issue. Not a big selection of 14mm wheels available, so conversion to 12mm or 17mm seemed like a good plan. I went the 12mm route because I already have a few sets of 85mm road wheels from my WLtoys 124019 "Purple Haze" build to play with.
Ordered a set of Arrma 12mm hexes P/N AR310816 that worked perfectly. The 12mms seem like a better casting and are more refined and not as blobby as the 14mms. Biggest difference is the pin length, but the Arrma 12mms come with the proper size pins.
After installing the 12mms, I test fit a couple of sets of 85mm tires with different offsets I had laying around.
Tire on left is part of a staggered set from Amazon
https://www.amazon.com/gp/product/B07ZTG9WXM/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
that are 85mm with fronts 32mm wide and rears 38mm wide with 0 offset.
Tire on right from ebay is the same diameter and width but with a -2mm offset.
https://www.ebay.com/itm/154939853890
Both of these sets are commonly available and have the same tire but with different offset rims. Both sets clear the body (the -2mms are really tight).
The 0 offsets:
The -2mm offsets:
I can work with these, we'll see how they perform.
Next was to get more adjustment in the body posts. The included ones have almost no adjustment travel, so I went with Arrma body posts for the Big Rock P/N AR320357.
Good selection of different length posts for future body swaps and clearance if I go with 17mm hex wheels in the future.
Here's the stance with the new body posts set one hole above factory front and rear and the 0mm offset wheels..
Here's an alternate body that I'm going to start working on. It's a Bittydesign ZL-21 drag body that is 25mm wider than the stock body giving a lot more wheel options.
The 0 offsets:
The -2mm offsets:
