Traxxas velineon 3500 can size?
550 size 3657 (36mm dia 57mm long)
You measure it as 36mm diameter and 57mm or 60mm long Hence 3657 or 3660
But if you comparing old money with new money I believe your answer is 550 size
The sinks that have a fan, is there a spot on the ESC to plug that in, or is it something ill have to wire in myself? I dont have the truck with me.. lol
The vxl-3s esc has a fan plug, but it's kind of intended for the esc fan. I put a splitter on mine to run a motor fan as well when I had it installed. If the esc is on, the fan has power and is on. It's not a temperature controlled output.
Depends on your ESC though. Not all of them have a fan plug/port on them.
