Getting new ballcups (for the steering / toe links)
10K diff oil (front)
30K diff oil (rear)
1M diff oil (center)
Also ordered 30wt and 40wt shock oils for Beach RC in August for vacation
The current tires I have on now which are the Swaggers are completely worn down
Getting new front tires. Getting JConcepts as they are pretty cheap, and premounted to the wheel
Getting both pairs of Pin Swags and Fuzz bites premounted.
The locals also recommended ProLine Harpoons front and rear. Didn't go that route as I need a new set of wheels, and its much more expensive.
Was thinking about getting the B74.2 battery mount and straps. I heard they fit the B74.1 with just some little trimming of the side guards so no problem. But I removed it from the cart as I'm very very low on money. (Not surprised) The thing I do not like about the kit battery strap is that it is carbon fiber, and you have to take out the screw inorder to put in and remove the battery which makes it a pain between races. Also to mention its a terrible design, well, on both .1 and .2 mounts and straps. I seen one guy had a problem snapping the .2 elastic straps.
With the tires, I am going to run 1 of them in 1 heat, and the other in the next heat, and in the main, I will determine which one I like the best. The other pair I have, I will keep for my uncle just incase if his swaggers get worn down quickly.
The rear tires are pretty good. Me and my uncle both run Schumacher Cactus rear and Swagger fronts so thats where I got the setup from.
And 1 thing I forgot. Got my new radio. Which is the RC8X for prime day. 255 instead of 320. Last chance to get it. I could of done the trade in program and still get it for 220, but it will take a while since it is coming from China. The RC8X should pair up with the receiver already in my buggy and mini b no problem (R6FG V4/V5 rx's). The only issue I will have is higher ms or refresh rate. Not to into that part of rx/tx. They do have the R8FG V2 receivers which can run down to 3ms but the problem is with both of the cars, it is super big and bulky, and dual long antennas. Hopefully Radiolink can come up with a receiver which is mini or micro, antenna-less, and run down to the lower ms rating or whatever it is. So my current radio (RC4GS V3) will be kept for my dad, and for bashing. Really don't want to throw around a expensive radio like that. Might move up to the higher grade Futaba and Sanwa stuff later on in the future.
Last Saturday, I test drove 2 cars. One of them was Lamont's Schumacher LD2 (2wd) buggy, and he has it paired up with his 10PX. Felt pretty good. Got used to driving it pretty fast as I had experience from the Mini B. The other car I drove was James's 22x4, and he has it paired up with his NB4. Felt really dialed in, and fast.
The other thing I am getting dialed in is the timing on the motor can. I was running whatever they had it set to from the factory which I think it was around 40 or 45 degrees. I had turned it up to 50 degrees and it felt a bit faster. One guy has the Hobbywing Tunealyser so he will let me use that to get it really dialed in. (Since this is stock, the timing is only allowed on the motor can, 0 turbo or boost timing through the ESC)
With all of these new tires, and timing adjustments, we will see if I can win the B main and get into the A. Just need a little more practice time with getting used to the new tires, and the more timing.
Won't be going down this Thursday for racing, but should be on Saturday. Running Mini B, and 1/10 if we got people. Last Saturday, it was test and tune, I was the only one who showed up besides the 2 owners and 3 other Mini Z racers.
