Team Associated RC10T84 1/10th 4wd Truggy
RustyUs
Military Veteran
Pennsylvania, USA
More info here: https://60years.associatedelectrics.com/rc10t84-team-kit/
The Team Associated RC10T84 Team Kit is Engineered for Victory!
Unleash unparalleled performance with the RC10T84 Team Kit, a 1/10-scale 4WD truck engineered for precision, speed, and racetrack victories. Designed with cutting-edge features, this competition machine delivers superior handling and control.
Its molded height-adjustable gearboxes ensure optimized drivetrain efficiency. The truck specific gull wing long-arm suspension geometry enhances grip and predictability, while the optimized steering bellcranks and rack provide exceptional bump steer control, keeping your lines tight at every corner.
Fine-tune your setup with chassis bracing adjustments, giving you the flexibility to adapt to each track you race on. The RC10T84 Team Kit allows for precise weight distribution and chassis balance, letting you push the limits with confidence
Enhanced aerodynamics come standard with an all new truck specific low-profile body paired with adjustable rear wing mount heights. The RC10T84 Team Kit is finished with shock tower covers, 3.5mm turnbuckles and ballcups, and 13mm big-bore shocks, providing the ultimate blend of strength, precision, and performance, the RC10T84 Team Kit is your key to placing on top of the podium!
Features​
  • New Truck Specific Gull Wing Long Arm Suspension
  • New Truck Specific Body
  • 25mm and 31mm Length 13mm Big-bore Shock Bodies
  • TiN gold 3x24mm and 3x29mm Shock Shafts
  • Molded Shock Tower Covers Front and Rear
  • New Wide Tongue Chassis for Improved Durability
  • New Wide A and B Mounts
  • New Molded Front Bumper with Optional Bumper That Covers Anti-roll Bar Mounts
  • Longer Front CVA Axle For Truck Specific Wheels
  • Center Differential Included
Required to Complete​
  • Motor
  • Battery
  • ESC
  • Servo
  • Receiver
  • Paint
  • Tires
  • Radio
  • Assembly and painting required
no. just no.
why the frick is there a buggy body on that truck? they made a muggy. looks more like a swamp buggy than a truck. i didn't know an RC car could be sexually confused. someone at AE needs to be fired. out of a cannon. into a brick wall. or maybe just kicked in the nuts one at a time. idk.
i don't think iv been this confused and pissed off at an RC car before. it makes me want to go buy an OG high CG slash. i feel like i need to sit on the end of a dock looking out over the lake at sunset contemplating life.
I've prayed to the RC gods for Team Associated to join in on the 4wd stadium truck/mini truggy action back in 2018. When they didn't, I moved to Tekno and their ET410. If Team Associated came out with this thing back in 2018, I still would not have bought one. Reason being it's for a well-groomed running environment. I could not see the T84 lasting long on the stuff I run my RC rides on.
no. just no.
Apparently they call those body styles as "Bruggie", sound dumb af to me. I like the rest of the truck though
well whoever conceived of it needs to be stabbed in the eye with a really hot french fry.
i blame ROAR and every other sanctioning body. why in the hell did they let manufactures mutilate bodies? there should have been strict guidelines in place to keep them looking like what they're supposed to look like. the cab/cockpit forward stuff never should have happened. the melted mutant choptop roof lines never should have happened. the side windows being in the middle of the doors never should have happened. exposed shock towers on a truck should not be happening.
If you go way back and read some old forums you find people complaining about how the RC10 ruined the appearance of buggies compared to the Tamiya rough rider and similar buggies decades after the rc10 took over. I think cab forward is ugly but exposed shock towers make it a buggy.
Roar made a big stink about buggies NOT being allowed to run TRUCK bodies...
How the hell can they tell one from another any more?
Roar took lessons from Musk I'm guessing.
They are trying to destroy pick up trucks as best as I can determine from what I see here.
This is a buggy with wide arms and a wider price tag.
maybe it's just me but I don't see this thing being as popular as the ET410 will be, given the latter is $200 cheaper, theoretically stronger (it is a Tekno) and that the B84 has a tendency to crack its chassis (assuming all they did to the T84's chassis was to slightly enlarge it)
buuuuuuuuut I'm not too sure about that given how some people are determined to have the latest everything
