I did not go to the hobby shop planning to b buy this...am glad I did though. The process has been a ton of fun. Soon on to the driving part. My plan is to keep it complete stock to be able to run in the local races.
It begins....
Haven't seen something like this for a while. Much rather do this. RTR means ready to rebuild....I just get to drive it before I tear it down for repairs and updates....or to be the first one to put lube in the diff....on to the fun stuff.
so many pieces....
Plastic drive shaft and bushings.....hhmmm
The infamous "torque tuned 540"
Because we haven't seen the bottom of the chassis yet...
Steering is almost a thing. Friction dampers installed, there is grease inside for better movement.
starting look like something...1st problem. The wheels are on there. The factory supplied hexes were so long I could not get even close to the rubber on the lock nut. I actually cut them down about 40 % to get the wheels on well enough to test drive. Still lost a wheel...not low enough. I ordered aluminum hexes at a 5mm thickness. The wheels fit right, I did narrow the stance by probably 3-4mm doing that.
I used the supplied mounts, and my own servo as needed to complete. I tried to get a pic of the mount on this side. If you can see it. I cut the mount in half so it only uses the chassis mount and lower servo mount on this side. Also I trimmed the top ear off the servo. At full throttle the driveshaft would rub and vibrate in ways even real bearings would make up for. Nice and smooth now!
the build is complete minus the new wheels hexes and green anodized wheel nuts. The usps guy was enjoying them for me at this time...
Body fitting, I did appreciate the precut wheel wells and the side mirror is just a push in with a body clip. It's like they think you will break them and made it quick and easy to fix....who does that? I might be 1 of a few people who did not buy this car for the body....not a style of racing I have ever followed. The build platform is the same throughout the line, and pricing reflects the licensing if the body until it becomes the Tt02R. A model I might pick up at the right price after having built this. Looks like a lot of upgrades in the right places for not too much extra. Painted body shown in a video below. I did not follow the plan on the box....I did use some stickers. A real "smokeshow" out back...hehe. no fancy hobby shop paint. Just random rattle cans I have around ...for reasons....mostly rustoleum.
It begins....
