starting
anythingfast
I've got a hyper7, when i get it started it revs like mad, tried everything to get it to idle properly but nothing works.What am i doing wrong.Can someone tell me please.
Check your Low Speed Needle. It may be too lean causing it to rev. Also check your radio trims and your throttle linkage to ensure they are setup correctly and the carb is not open a hair. Yank your air filter and check your idle gap as well. It should be @ 1mm (thickness of a credit card) or so.
When I totally hose all my needle settings I have found setting all the needles and the idle screw back to factory defaults helps me everytime. :D
