Hello! I am fairly experienced with electric cars and just built my first nitro - a Kyosho Inferno MP10T with a Reds 521 Sport 0.21 engine.
The issue is....I can't start it. At the time I tried to start it, the flywheel was only able to turn one full revolution or so before it stops. I primed the engine with fuel using the blow method (Morgan Fuel Sidewinder On-Road Nitro Fuel 16% - because I read this is a good fuel for initial break-in), put in a brand new charged glow plug igniter, and fired up my ProTek starter box. The starter wheel rubber gets totally shaved off and smokes against the stuck flywheel....so clearly something ain't right. I also heard that perhaps I should heat the engine. I heated it with a heat gun that didn't help at all. I don't know how hot it got because I didn't have an infrared thermometer at the time. Just bought one of those so I can be sure the temp is hot enough. 200 degrees?
I guess my main question is whether the fact that the flywheel doesn't turn freely means that I assembled something incorrectly or that there's a problem with the brand new engine. By the way I did try removing the glow plug and that had no impact. At this point, the flywheel is just stuck and I think the piston is at the top of its travel and won't come down. Any advice for this novice??
