So I want to run a starter box on a single 4s battery will a Deans ESC Loop Jumper Plug Lead Connector close the one end of the Y and make it function correctly?
Yep, so if you just have a deans jumper (anything to complete the series circuit on one side of the Y. Basically short one end to the other) and a 4s battery on the other deans, you should be good to go
Battery Note: The SureStart comes equipped with a Y-Harness power lead to accommodate either two 2S LiPo or two 6-Cell NiMH batteries. You can however use a single 4S LiPo battery to power the SureStart, BUT some modification is required - you will need to remove the Y-Harness power lead and re-solder a single T-Style connector to the power leads.
Bro i made my starter box so all i have to do is hook a battery to it and bumb start ran to leed wires oit sidecthe box and then you can hook any kind of small lawn equipment battery to it
Yeah I was going to run it off my car battery with 10amp alligator clips like we did way back when. But found a 4s LiPo for 33 bucks so went that route instead.
