jimmy2k
Having a strange issue with my tmaxx and the ez start. When I try to start my truck, the starter motor just spins without engaging the motor. But, if i 'bump' the starter, by tapping the starter button on-off-on-off,etc, it will eventually 'catch' and start.
The motor has good compression
All the gear teeth are fine in the ez-start
The electric starter motor teeth mesh fine with the starter gears
The starter works fine when unmounted from the motor
One way bearing is on correct and catches fine.
Any Ideas?
Any Ideas?
