bgbdwlf2500
Ok so I finally found the manufacturers specs on the type and size box to build for my setup. Problem is to run 2 subs built to their specs it just ain't gonna fit.
So heres their numbers:
Height 15.71
Width 25.42
Depth 9.709
For an empty box total of 2.244 cu ft.
Those dimensions are the inside number and they say to use 1" material so outside dimensions are 2" bigger than that.
My problem is 54" is way to long and the height is overkill. Depth is probably about right.
So I came up with a 30x16x16 and that was really close to being the correct volume for two woofers. What other dimensions could be used? Anybody have a program that might help? They are 12" woofers and I want them mounted either on the front or back not top or bottom.
Probably have 38" length easy to work with and I think the dimension they used for the depth is about as small as you can go.
The formula is h x w x d /1728
I could sit here and throw in numbers all night but figured someone here might have a program or something that could do it
Height 15.71
Width 25.42
Depth 9.709
