martinmarty
RCNT Rookie
Sorry if I don't have the terms right. I hope you can tell what I am talking about.
There is a small spacer (they call it a limiter) that goes on the shaft below the E clip below the piston. The Traxxas (plastic) shock instruction sheet says to use these spacers on the rear shocks. The big bore kit instructions do not mention the spacer, but they give them to you, so I put them on.
It appears that this spacer prevents the shock from extending fully, by its thickness, approx. 1/16".
What is the significance of this spacer or limiter, and why is it only needed on the rear shocks?
Question #2) At the bottom of the big bores, there is a tiny C clip that holds in the o-rings, etc. What do you use to get these in and out?
THANKS
THANKS
