WickedFog
Community Leader
RC Showcase: 9
- Terre Haute, IN
- Crawling
- Scale Builder
You can do either or.Do the winches use a different power supply?
This controller lets you control your winch with channel 3
https://store.rc4wd.com/RC4WD-Wired-Winch-Control-Unit_p_3725.html
You would likely be fine with a 10A BEC to be honest. But I would go bigger just to be sure. If you can find the current rating for your servos and winch, you can figure what the max current is of course. Like your winch and steering servo will be your biggest draws. As long as you have a few extra amps beyond what they'll be pulling, you should be fine.No have 2 tail lights and 2 headlights. Thatd take maybe an amp if that i figure who knows aha. Later id add underglow rock lights. But i have a spektrum micro servo for dig. I need 1 more for 2 speed both of those are only on when i stop and flick them so no steering servo woukd be used. And its less than a second to activate then off. Only lights and steering and when i need the winch. But i can turn off the lights if needed. Not sure winch draw is.
My steering servo is bigger than the micro thats all i know without tesring it out
Nope was told the receiver can handle them i hope
