Rx Battery NO NO!!
Mickstix
RCTalk Champion
Debary, Fl.
Well, here's a picture of what NOT to do.. :D I wanted to cycle my new 6V "hump" pack Reciever battery, so I charged it up and then hooked it to my old "bulb" discharger.. I think that might be a tad too much draw for the little BEC battery plug adapter!! LOL.. As you can see it melted the wires in about 3 seconds.. So my next question, does anyone know how to get the little metal "pins" out of the BEC plug? (the little black female plug) so I can rebuild my BEC battery adapter?? Thanks.. ;)
That entire connector is toast. Buy a new one.
Yeah... I've come close to that before. I used a couple spare tail/brake lights from my MGM. I wired both the elements in parallel and use just one bulb to discharge/cycle my AA's. Running two wired that way (4 elements) makes the connector pretty warm pretty quick. I guess I see what 5 times that will do!
Yea, it was fun for a second.. lol.. I would just buy new adapter, but my LHS doesn't have it.. All they have is an "octopus" adapter with like 6 different leads, for something like $20.. EEK!!! I'll just make a new one if I can get these pins out of the BEC housing w/o ruining it.. I can get em' out of the Tamiya end no problem.. And I've got plenty of "good" wire to rebuild it.. (I got this one with an online order.. If I reordered it's cost more for shipping than the adapter) Someone told me RadioShack has the male/female BEC plugs though, so I'm gonna check them out tomorrow!! ;)
Olds, you said you wired 2 elements but used 1 bulb? I dont follow ya? You dont have a pic of it do ya? I need something to cycle these 6v hump packs.. Thanks!
The original issue (too much draw for wire rating) has been very educational. Never thought that the wire rating was important in using a "bulb discharger", but now since i have read this thread, it makes sense.
He's probably referring to an automotive 1157 parking/brake bulb. 2 offset + spots and a common case ground.
Close to that. Newer bulbs don't appear to share a ground anymore. They have a plastic wedge that has 4 leads on it that make contact with 4 contacts in the plug. Regardless, the end result is the same. Brake element, running lamp element, 1 bulb. The brake element draws a lot more current since it's a much heavier element. Seems to be sufficient for cycling AA packs. I use them on occasion to dump my AA's in my transmitter as well.
Either I have really good batteries, or the cycling of servos/transmitters don't draw much life out of them as some of my cells have been in use for 3+ years. I run an entire day on one charge on any of them. Granted, a day means 2-3 hours of actual driving, but rarely do I shut things off in a 4 hour time period of running.
I normally charge everything up the night before, then top off before heading out the door in the morning. That probably plays a part as well.
Anyway... didn't mean to derail. ;)
Thanks for the added info Olds!! If I can find some bulbs I'll make a new discharger with just 1 or 2 bulbs, for my rx and tx packs..
