RPM Axial Yeti XL Front Lower A-arms
WoodiE
Kind of good admin
Administrator
Lexington, KY
RPM has designed a set of lower front a-arms for the Axial Yeti XL. Not only made from their well known nylon blend that is incredible durable but RPM has also improved the lower front a-arms by removing as much as 0.004" (0.1mm) of slop from the inner and outer hinge pins. RPM has also added additional clearance around the bellcrank center-link to allow for more up-travel without the impact that the stock A-arms and center-link encounter at full suspension up-travel.
Click to continue
