sweetdiesel
aka SouRGassssssss
Here is a tool that is not used very often but is very handy when you need it. The RMV flywheel puller allows you to easily and gently remove the flywheel from the engine without damage to the flywheel or crankshaft. Usage is easy, just slip the two jaws over your flywheel and line up the center shaft with the end of the crank. Slowly turn the handles and your flywheel is gently pulled off. I used to stick my flywheel in a vise and hammer the crankshaft until one day I ended up mushrooming the end of my crankshaft, not to mention warping my flywheel from being squeezed in the vise. With the RMV tool, those days are over.
http://www.amainhobbies.com/product_info.php/cPath/89_139/products_id/4098
