Dizzyotes88
RCTalk Racer
- Thread starter
- #41
We are running thru glow plugs at the moment.... I've always just bought whatever glow plug. Well the ones that the hobby bench guy gave me to buy. Never noticed what they were.
So number 8's? Got it. Thank you.O.S Glow Plug R5 (12pcs) | eBay I buy my plugs here. I only use Os #8 cheapest around. As for soaking the carb in something other than After run oil. it may damage the O-rings in side the carb?
Engine manual says R5 for high nitroSo number 8's? Got it. Thank you.
run between 20-30% nitro content, and 9-12% oil, too much oil is not good, all it will do is cause headaches with tuning, and run hotter when you get to the tuning window. 14% is on the higher side, but still reasonable, but i would not recommend going any higher.So a few things. We've gotten the motor to run as far as the old 3.5 goes. Went to an rc store yesterday and they put a known good working tune on the motor. And it ran in the store. Talked to them about fuel. Was talked very seriously to about not running any fuel with more than 9% oil in it. I am in Arizona. It's very dry here. Was told higher oil content is bad for the motor here. So I bought fuel there with the right everything.
The other thing, that 4.6 motor will run once I get the shims, but it's got something scored inside it and won't last long. So this morning I ordered the dynamite motor. Not the big red version. But the one just below it. I'll buy the big red version next week. Now we are just trying to get this stupid thing to run here at home like it did in the store yesterday. We even changed it back over to roto start.
I'm keep going with updates.
NO! dont mix up O.S. R5 with HPI R5! O.S. plugs are SHORT plugs, HPI Plugs are long/standard!Engine manual says R5 for high nitro
You need R5 cold for high nitro. O.S. OS Engine R5 Glow Plugs (OS R 5 #R5 plug )12 pcs FREE SHIPPING | eBay
find a standard length medium plug, Dynamite makes good ones, or get an O.S. LC4.So number 8's? Got it. Thank you.
for uploading videos if you dont have a youtube or something, I've found "streamable.com" works well, just drag the vid to the browser, let it do its uploading then post a link. they arent permanent links though so after a few months they do expire unless you do the paid version. in those cases definitely helps to use YT or somethingNevermind. It won't load
