Yes it's already turning to the right side but it has something to scrape and hold and still do not know what it can be so I'll have to open it again to see what's going on...
But I've been watching starter box now all that's left is opportunity to buy
It's not a wire it's just string. If it is a wire then it's not supposed to have wire. What do you mean you curl the end to make it easier?? I'm confused so the pull start had wire wrapped around the spool?
The OP is Portuguese and uses a translator to translate what hes saying to English so I'm guessing the translator isnt properly translating all the words correctly. I know when I use google translate to convert english to tagalog to send a message to my wifes family in the Philippines my wife told me its mostly understandable but butchers the translation a fair amount.
I'm sorry, I meant the spring, it gets easier with the spring already in place
As the greywolf said the translator does not always put the correct words
Excuse me ,it was a roto start ,an it started on a kick back ,where the piston did not make it
over on the down stroke ,an the compression forced it to go the opposite way an started
backwards!
