Nitro_Freak
why don't you go to you lhs and have them help you out, it's kinda hard to eplain over the interent...
ImBroken said:I would replace the shims anyway, along with the 4 bolts, & put it back together.. The head has got to be torqued down evenly in a criss cross fashion.
Yes, when there are no screws to hold the underhead (the silver thing that holds the glow plug on) on then the compression of the engine will force the underhead upward unless held on.6_dman_6 said:Was that a question? Well the screws only wiggle when checked without the cooling head on and only with the part that holds the glow plug in on. I only put the screws in halfway and they wiggled a little.
Also when the cooling head is off the part that holds the glow plug in shoots up when you pull the pull start that is normal, right?
olds97_lss said:First of all, is there a shim? Secondly, the screw slop when not tight is normal. These things aren't built by nasa, so there may be some slop in some things.
How about some backstory...
What vehicle is it?
What engine is it?
When did it start spewing fuel out on you?
What did you do to it just before that happened?
Did you buy it that way?
Is this your first nitro experiance?
How old is the engine if it's not new? (how many gallons have been through it)
What were your engine temps when it was running?
Did it ever run?
What have you tried up to this point before you started asking questions?
Are you less than 20 years old? (I don't really care, but if I decide to go on a swearing tangent, I want to know I'm not cussing out an 8 year old...)
If your LHS sucks, all we can do is suggest things, since we can't be there for ourselves. If you have a camera that can take clear pics, clean everything up, take a pic before you take it apart. Take the head off, take a pic. Show us a pic of both sides of the shim. Show us a pic of the underside of the engine head with it off. Show us a pic of the crank case top straight down and a pic of each side with the head off.
Corrected. I hate spelling too... don't know how I missed it, that stuff drives me nuts.olds97_lss said:Patience... I hate spelling...
Jesus, here we go again. What the hell is that supposed to mean?! Do you honestly think we are supposed to make sense out of what you say?6_dman_6 said:My friend that's bad luck is gone so I may take it out.
Enough jiberish... what was the problem?6_dman_6 said:well, I think I figured it out. It stopped hissing and now the muffler just makes noises.
Or in his case, a LOT.All it takes is to simply read your post back to yourself before you send it. I do this and usually get something that other people can read =)
