Official SORRCA Scaler Rules.
slowngreen
Robmob is a Californian.
Staff member
IDAHO
  3. Crawling
These are the official SORRCA (scale off road rc association) for scaler in a competition.
SORRCA
Scale Off Road RC Association
Official Scale Rock Crawling Competition Rules (2011)
General Construction (IN ALL CLASSES OF COMPETITION)
• TWIN VERTICAL PLATE (TVP) CHASSIS ARE NOT ALLOWED, INCLUDING TVP CHASSIS
WITH FRAME EXTENSIONS. Examples of non‐permitted chassis are: SWX, J2‐TT, GC‐2,
Edge, Eclipse, Hustler, etc.
• All vehicles must have a chassis and body (or unibody). On full‐tube rigs class‐specific
requirements apply; see class descriptions.
• No "Motor On Axle" (MOA) of any kind. Your axles must be driven by one transmission
or transfer case and a minimum of two drive shafts (except CC‐01, TA*‐02 etc..). No
separate throttle control of drive shafts or axles.
• Multiple axle vehicles are allowed, but must follow all other class rules.
• No batteries or electronics (excluding steering servos) are allowed to be mounted on the
suspension, links or axles.
• BANNED TIRE LIST (the following tires are not allowed): Losi Comp Claws; Imex red
rocks, skulls and bones; Hot Bodies Rovers, Sedonas; Panther Cougars, Leopards;
Jconcepts RocX; Pro‐Line Chisels; RC4WD Rocklins, Crazy crawler, X‐locks; Losi Bashers;
Any buggy tires, truck racing type tire, pin tires.**
If you want to run a tire on this list, you must bring a picture of it mounted on a 1:1 vehicle for it
to be considered.
• Tires sizes are determined by listed manufacturer size or size printed on the sidewall. If
that is not available, then the tire is measured dismounted and laying on its side.
• Wheels may be no larger than 2.2” and both the inner and outer bead must be the same
diameter.
• Each vehicle must have a minimum of 20 “scale” points in order to compete at a
national event.
Class Descriptions
Class 1 ‐*A street legal, daily driver mildly modified for trail use.
1. Tires
1.1 Maximum tire outside diameter of 4.19” as advertised by the manufacturer. Tire diameter
and width must be as designed by the manufacturer and may not be modified.
1.2 Tire lugs may not be removed, siped, grooved or otherwise modified from stock. No other
modifications may be made.
1.3 No competition specific tires allowed (see banned tire list).
1.4 Both front and rear tires must be covered by the body or fender flares with no more than
one quarter inch of the tire tread surface extending beyond the body (as viewed from above)
with measurement taken at the axle center line.**
1.5 Full coverage fender flares, tube fenders, and flat fenders are allowed but must be attached
to the body along the entire wheel well opening.**
1.6 Exo cage tube work does not add to tire coverage.
2.Wheelbase
2.1 No maximum or minimum wheelbase limit. Wheelbase should be within one half inch
(total) of the center line of the factory wheel well openings of body.
3. Chassis
3.1 All Chassis must run the full length of the vehicle, from bumper to bumper.
3.2. Chassis may ONLY be ladder frame, molded tub or uni‐body.
4. Bodies
4.1 No tubers or rear tubed (truggy) bodies allowed.
4.2 Flatbed length must be at least two thirds as long as the wheelbase and must be at least as
wide as the cab at doors all the way to the back.
4.3 No dove‐tailing, pinching, boat‐siding, bed bobbing or other performance modifications
allowed.
4.4 Minor trimming of fender flare or lip is allowed.
4.5 Full width bumpers are required on the front and rear of the vehicle. Bumpers that are
molded into the body qualify. A rear bumper is not required on a flatbed, but adding one to the
flatbed will get the additional scale points.
4.6 All vehicles must have a windshield and it must fill in the entire window frame.
5. Other.
5.1 Vehicles must have the motor, transmission, and electronics covered and hidden when
viewed from the top and sides.
5.2 No dig or rear steer in Class 1.
Class 2 ‐*Performance trail truck, not necessarily street legal.
1. Tires
1.1. Max tire outside diameter 4.75" as indicated by the manufacturer. The tire diameter and
1.2. Tire lugs may be removed, siped, grooved and trimmed.
2.Wheelbase
2.1 No maximum or minimum wheelbase limit. Wheelbase should 'fit' truck concept/body.
3. Chassis
3.1. Overall chassis length (including bumpers) must be at least three inches longer than your
wheelbase. Placement of the chassis over the wheelbase (centered, offset front or rear) is left
to the discretion of the driver/builder. Stingers, spare tire carriers, winch plates, or other
bumper mounted accessories are not included in the overall chassis length measurement.
3.2. Chassis may ONLY be ladder frame, back‐halved ladder frame, molded tub or uni‐body. No
full round tube chassis in Class 2.
4. Bodies
4.1. Vehicle body from front to rear of driver/passenger doors must be wider than the distance
between the inside of the front tires.
4.2. The vehicle's body must measure no less than four and one half inches vertically from the
top of the roof or roll cage to the lowest part of the side/door/rocker panel. Boat‐sides may be
included in this measurement, but are limited to one inch vertical height from the line where it
meets the body to the point it meets the chassis/frame.
4.3. All the vehicles, at the minimum, must use: production style hood, 50% of the production
style front fenders, 50% of the production grill, roof (or roll cage if an open top), plus two of the
following:
‐*Windshield and frame
‐*Rear quarter panels
‐*Doors/half doors
‐*Rear Bed/cargo area
4.4. Two of the following three body modifications are allowed:
‐Pinched front (must be no less than two thirds the width of the widest part of your cab)
‐Dove‐tail (must appear scale*‐*a truggy/tube bed that is narrower than the cab counts as dove‐
tail).
‐Boat‐sides (see 4.2 above)
5. Other
5.1. Vehicles without an enclosed cab and/or doors must have the motor, transmission, and
electronics in the interior (drivers and passengers compartment) covered and hidden from view
5.2. No dig or rear steer in Class 2.
Class 3 ‐*TTC/KOH/extreme trail truck
1. Tires
1.1 Maximum tire outside diameter of 5.75” as measured.
1.2 Tire diameter and width may be reduced, enlarged or combined with other scale tire treads
as desired. The modified tire diameter measurement will be taken with the tire/wheel laying on
its side, without vehicle weight on it.
1.3 Tire lugs may be removed, siped, grooved or otherwise modified.
1.4 No competition specific tires allowed (see banned tire list). Modified tires must still
resemble a scale tire in design.
2.Wheelbase
3. Chassis
3.1 Overall chassis length (including bumpers) must be at least as long as the wheelbase.
Stingers, spare tire carriers, winch plates, or other bumper mounted accessories are not
3.2 Chassis may be a ladder frame, back‐halved ladder frame, molded tub, uni‐body or a tuber.
4. Bodies
4.1. All bodies (including tubers) must measure a minimum of five inches wide from front to
rear of door, two inches above the skid and must measure a minimum of five inches tall as
measured from the skid to the tallest point on the body.**
4.2. Body modifications including, but not limited to, pinched front, dove‐tailing and boat‐siding
are permitted as long as the final dimensions comply with the aforementioned rules.
4.3 Tubers must have at least panels or scale vehicle components (tool boxes, fuel cells, etc..) to
conceal the electronics.
5. Other
5.1 Vehicles without an enclosed cab and/or doors must have the motor, transmission, and
electronics in the interior (drivers and passengers compartment) covered and hidden when
5.2 Dig and/or rear steer are permitted. However, only the use of one or the other will be
allowed (per course) with the choice being left to driver’s discretion.
5.2.1 The initial use of dig or rear steer will incur a onetime penalty of +5 per course.
5.2.2 If during that same course you engage the other one, there will be a +10 penalty assessed
and your vehicle will be placed back at the last gate cleared on that course. The same penalty
will be assessed each time you use that item.
Scale points
Duplicate items/features do not receive additional points unless otherwise noted. No item/feature will
be counted twice. Items/features with a number in brackets require that number to receive points.
Chassis/Body :
1.1 Tube bed**
‐*Tube bed: metal*‐3, plastic*‐1**
‐*Bed area 4 point roll bar: metal – 2, plastic*‐1
1.2 Flat bed**
‐*Flat bed: metal/wood*‐3, plastic*‐1
‐*Bed mounted headache rack: metal*‐2, plastic*‐1
1.3 Truggy & back halved truck**
Truggy/back halved truck: metal*‐7, plastic*‐3
‐Must replace the ladder frame from the rear of the skid to the back of the vehicle. Must have a roll bar
hoop. Must have integrated shock mounts. Must be a structural part of the rear of the vehicle. (If your
bed does not meet ALL of the preceding criteria, it does not count as a truggy bed).
1.4 Drop bed
‐inside of a tube bed/truggy bed*‐2
‐inside of a standard pickup bed*‐3
2.1 Interior cage or exo‐cage (may only choose one)
‐*3 row cage: metal*‐10, plastic*‐4**
‐*2 row cage: metal*‐8, plastic*‐3
‐*1 row cage: metal*‐5, plastic*‐2
3.1 Tube accessories
‐*Sliders: (both sides) metal*‐3, plastic*‐1
‐*Tube fenders:*‐1 per pair**
‐*Front cage:*‐3
‐*Rear tube structure: metal*‐2, plastic*‐1
‐*Integrated tube shock mounts:*‐1 (per pair)
4.1 Body**
‐*Hard body: full‐8, half*‐4
‐*Drop bed :*‐3
‐*Custom built body: (metal or hard plastic, no lexan) full*‐4, half*‐2
‐*Inner fender wells:*‐1 per pair
5.1 Bumpers (items must be chassis mounted and separate from the body)
‐*Full width bumpers : metal*‐3 each , plastic*‐1 each**
‐*Narrow bumpers : metal*‐1 each**
‐*Stinger/grill guard:*‐1
‐*Spare tire carrier (must be bumper mounted):*‐1
6.1 Exterior roof rack / light bar (may only choose one)
‐*Large roof rack: metal*‐3, plastic*‐1**
‐*Medium roof rack: metal*‐2, plastic*‐1
‐*Small roof rack: metal:*‐1**
‐*Roof top light bar : metal*‐1
Interior:
‐3D interior:**2 seat*‐3, 4 seat*‐5, SUV cargo area*‐1.
‐2D/half interior:**2 seat*‐1, 4 seat*‐2.
‐*Realistic Scale Human figures: full*‐2, part*‐1 (max 2 figures)
Suspension/Drive train/Steering:
‐Leaf springs (front/rear):*‐3 ea,*‐7 both.
‐Multiple axles: 3 driven axles*‐3, 4 (or more) driven axles*‐5**
‐Chassis mounted steering servo:*‐5 front,*‐3 rear (rear steering in class 3 only)
‐Transfer case:*‐4.
‐3D engine:*‐4.
Realistic exterior items (max*‐5 pts):
‐*Fuel cell, exhaust, jerry can, hubs on all wheels, steering stabilizer, disc/drum brakes on all
wheels, mirrors(2), wipers(2), antenna, license plate, Etc.*‐1 each
Functional items (max*‐6 pts):
‐*Tow strap,*‐D‐ring, Pull Pal, sand ladder, hitch, Etc.*‐1 each
‐Headlights(2) and taillights(2), winch.*‐2 each
‐Full size spare tire.*‐3
Miscellaneous scale items 1 (max*‐2):
‐Fire extinguisher, first aid, trail tools (Hi‐lift jack, etc.), tool box, ETC.*‐1 each
Miscellaneous scale items 2 (max*‐2):
‐Canoe, boat, camping gear, animals (dead or alive), lumber, lunchbox, drinks, laptop, scale r/c truck, etc.*‐1 each
RULES LINK: http://www.noeither.com/ScaleRules/RulesV10.pdf
Here are more rules for SORrRCA competitions
SORRCA Rules & Specs. Course points & penalties​
This rulebook is intended to standardize scale off road RC competitions that are held at various locations throughout the world. The intention is for all clubs/events to use these rules as written; however, they may be modified on a local basis. Any and all changes made to these rules at a SORRCA sanctioned event must be covered in a preliminary drivers meeting and publicly posted before the event.
-The first rule of any Crawl Space scale event is to have fun! We are dedicated to fun and healthy competition with a family freindly setting and respecting the land and everyone in the RC scaler/crawler community.
Class Descriptions: Class-1 "Street" • Description - A street legal off-road vehicle that you would drive to work or the trail head and outfit like an expedition vehicle such as the Camel Trophy truck D90 rigs.
Class-2 "Trail" • Description - A stock vehicle that has been modified to become a capable trail rated rig and is not necessarily street legal .
Class-3 "Modified" • Description - An off-road vehicle that you would build from the ground up and might see in a TTC/KOH type competition.
General Vehicle Details • You are encouraged to go above and beyond to make your truck as scale as possible.
• Vehicles must resemble a real 1:1 rig. It will be up to the collective group to vote on whether a questionable rig is accepted or not.
• Tire size will be determined by advertised manufacturer specs (tires without available specs will be measured off the truck as mounted on the wheel laid flat).
•Tire modification: Class-1 Street. No external tire modification is allowed.
• Class-2 Trail. Tire lugs may be removed, siped, grooved and/or trimmed.
• Class-3 Modified. Tire modifications are permitted, as long as the tire is no larger than 5.75" in diameter measured off the vehicle laying on its side, and all tire parts are from a legal scale tire.
• You must run a rail chassis (for example: Bruiser/Mountaineer, SCX-10, Reign RC K2-3S, 3L, 4, 5, MFM, X-Trail, CR-01, UTE, etc...).
• No TVP (twin vertical plate) chassis' or frame rail extensions on a TVPs.
• Tub chassis' are allowed, but chassis must be covered by the body and follow all other scale rules per class guidelines. An example of a tub chassis vehicle is CC-01, DF01, Twin Hammers, etc.
• 4-wheel steering or dig is allowed in modified class only (you must choose 1 per course).
• No "Motor On Axle" (MOA) of any kind. All motors, transmissions, and other electronics (other than steering servos) must be chassis or frame mounted. Your axles must be driven by one transmission or transfer case and a minimum of two driveshafts (except CC-01, TA-02, etc) No separate throttle control of drive shafts or axles.
• There are no wheel size distinctions. For example, you can run a 1.55, 1.9, 2.0 or 2.2 rim in any class. Wheels larger than 2.2 are not allowed in any class and no short course style wheels with split diameters.
• Spare tires must be within 1/4" diameter of your drive tires to receive points.
• Any functional recovery tools you wish to use during your run, you must carry it on your rig at all times. IE tow strap, pull pal, and sand ladders.
• Winching can only be performed off of natural objects (i.e. trees, rocks, etc...), other vehicles, or stakes supplied by the course builder. Winching off of a person such as their shoe or hand is not allowed.
• All vehicles should have the motor, transmission, and electronics covered and hidden when viewed from the top and sides. Batteries must be chassis mounted and should be hidden from view.
• Courses will be tough and made to push the scale vehicle's limits. This is to encourage competitors to improve their rigs from one event to another.
• Winches are HIGHLY recommended!!!!! Expect to use a winch.
• Water proofing is HIGHLY recommended!!!!! Expect your rig to get wet.
Tire Ban List: • Losi Claws (all sizes, and types) • Hot Bodies Rovers (all sizes) • Hot Bodies Sedonas • HPI Rock Grabbers • Panther Cougars • Panther Leopards • Pro-Line Chisels (all sizes) • RC4WD Rocklin • RC4WD X-Locks (all sizes) • RC4WD Crazy Crawlers • Imex Skulls and Bones • Losi Bashers.
Tires should be scale appearing, if it is questionable have it reviewed before the event, or plan to run a different tire. As new competition specific tires are released this list may be updated.
Class-1 "Street" Details: • Vehicle must have a windshield that fills the entire windshield frame. • Full width bumpers are required on the front and rear of the vehicle. Bumpers that are molded into the body qualify. A rear bumper is not required on a flatbed, but adding one to the flatbed will gain the additional scale points. (Bumpers are measured from the outsides and must be the width of your windshield). • Wheels must be aligned within the body wheel wells (center of wheels to center of wheel wells +/- 1/2 inch total combined) • The vehicles body must be mostly intact. Only mild trimming such as flairs & removing a hardtop are allowed. If the hardtop is removed, a full interior is required (no extreme trimming of bodies allowed *See below.) • The tread of the tires cannot extend outside of the wheel wells more then 1/2 of the tread width, flairs can be added to reach min. spec. • Vehicle must run a full length rail chassis (The rail chassis must be as long as the vehicles wheelbase)(Tamiya CC-01 chassis are allowed). • Truggies are not allowed, flatbeds with full length rail chassis are allowed. The bed must be as wide as the cab the entire length of the bed. Cab only not allowed. • Tires can never extend beyond the body’s bumpers or the rear of any truck bed. (Any stingers, fairleads, shackles, bolts, etc are not considered part of a bumper when determining this.) • Dovetailing is not allowed. • Sectioning or narrowing of the body is not allowed. • Bobbing a truck bed is allowed, but must follow all body specs. • Boat sides are not allowed. • 106mm / 4.19" Max tire size including spares. • Gates will be a minimum of 11" wide (so mind your width).Class-2 "Trail" Details: • Body/cage work must be at least 4.5" tall (including boat sides) and the inside of the front tires cannot extend outside of the width of the cab at the doors. • A front bumper is required and must be mounted to the vehicle's rail chassis and must be wider than the outside of the chassis rails (chassis cross rails do not count as bumpers). • You must run a full rail chassis, and the chassis (including bumpers) must be 3" longer than the wheelbase (this includes a chassis with a truggy rear frame). •Truggies are allowed, but you must replace the ladder frame behind the cab with tube, and the truggy rails must extend past the rear axle pumpkin to be legal. The bed must have a roll bar hoop and integrated shock mounts. It also must be a structural part of the rear of the vehicle. (If your bed does not meet ALL of the preceding criteria, it does not count as a truggy bed). • Flatbeds that run the full length of the rail chassis are allowed. The bed must be as wide as the cab the entire length of the bed. • 2 of the 3 following modifications are allowed: - Dovetailing the rear (1/2 the width of the widest part of the cab) *a truggy/tube bed that is narrower than the cab counts as a dovetail*. - Boat sides (no more than 1.25" measured vertically from the bottom of the skid). - Pinching the front (2/3 the width of the widest part of the cab). • 120mm / 4.75" max tire size with a 2.2 max rim size including spare. • Gates will be a minimum of 12" wide (so mind your width).
Class-3 "Modified" Details: • 146mm / 5.75" max tire size with a 2.2 max rim size (including spare). • A bumper is not required, but to be counted for points it must be mounted to the vehicle's chassis and wider than the the chassis rails (chassis cross rails do not count as bumpers). • Gates will be a minimum of 13" wide.
• Class 3 body minimum specs: Rock sliders, mirrors, etc do not count in these measurements: - The distance between the inside of the tires (of any axle) can be no greater than 1.25" more than the width of the body at the doors. *Example* (7" inside-of-tire to inside-of-tire = body must be 5.75" wide). - The body must be at least 5" wide from the front to the rear of the doors.
- Tire height can be no more than 0.5" taller than cab height. Height is measured from the bottom of the skid to the top of the bodywork/tube not including a light bar. (5.5" tire = 5" tall from bottom of skid to top of cab/tubework) - Body must be at least as long as the wheelbase of the vehicle. • Body modifications including, but not limited to, pinched front, dove-tailing and boat-siding are permitted as long as the final dimensions comply with the minimum size rule.Scale Points: Scale points are to be awarded at 50% of a vehicles total value (rounded down if necessary) for an average 10 gate course. Minimum/Maximum values are to be determined by the event organizers or local clubs. Scale points will be applied to a DNF but not to a DNS.
*No items can be counted more than once unless noted otherwise*
Bed: Not available to tubers.
-Tube bed OR flatbed: metal -3, plastic -1
-Bed mounted headache rack or roll bar: metal -2 plastic -1
•Truggy/back halved truck: metal -4, plastic -2 (Must replace the ladder frame behind the cab with tube, and must extend past the rear axle pumpkin to be legal. The bed must have a roll bar hoop and integrated shock mounts. It also must be a structural part of the rear of the vehicle. (If your bed does not meet ALL of the preceding criteria, it does not count as a truggy bed).
Tube bed, roll bar, shock mount points not available in addition to truggy bed points.
Tuber: metal -8, plastic -4. A tuber consists of a complete body structure where the front, cab, and rear sections are comprised entirely of structural tubework. Tube bed, roll bar, internal cage, and shock mounts points not available in addition to tuber points.
-Rigid metal/plastic body panels -1
-Interior cage or exo-cage: (-3 metal -1 plastic) per row of seats or area where seats would be (vehicle doesn't need an interior to get these points). Cage must have down bars and cross bars in front and behind each row. Not available to tubers.
-Tube accessories: • Sliders: (both sides) metal -3, plastic -1
-Integrated tube shock mounts: metal and brazed/welded to frame -1 (per pair)
Body:
-Hard body: full -8, cab -4 • Drop bed : -3. -Complete custom built body: (metal or hard plastic, no lexan) full -4, Cab -2 (in addition to hard body points)
-Inner fender wells: -1 per pair.
-Bumpers : metal -3 each , plastic -1 each.
-Stinger/grill guard: -1
Exterior roof rack/light bar (may only choose one)
-Roof rack: metal: -2, plastic -1. -Roof top light bar metal -1.
Interior.
-3D interior: 1 seat -3, 2 seat (or bench) -4, 4 seat -5 (any 3D interior must include seat, dash, steering wheel and floor). A 3D SUV cargo area will be awarded an additional -1
-2D/half interior: 1 seat -1, 2 seat -2, 4 seat -3. • Driver/passenger must be human, scale sized adult figures. Only available if accompanied by an interior.
-4 Complete Figure -3 Knees Up -2 Torso Up -1 Head with arms -1 point for 3rd and 4th passengers (Kids OK for 3rd & 4th passengers
Suspension/drivetrain/steering.
-Leaf springs (front/rear): -3 ea, -7 both.
-Multiple axles: 3 driven axles -3, 4 (or more) driven axles -5
-Chassis mounted steering servo: -5 (front) -2 (rear) *rear= Class 3 only*
-Functioning transfer case: -4.
-3D engine: Must be in a reasonable location and appear to be powering the drivetrain of the vehicle (-4)
Realistic exterior items (max -6 pts): Items that are non-functional but you would see on a trail truck.
-Fuel cell, exhaust, jerry can, hubs on all wheels, steering stabilizer, disc/drum brakes on all wheels, mirrors(2), wipers(2), antenna, license plate, fire extinguisher, trail tools (Hi-lift jack, etc.) first aid, etc. -1 each.
Functional items (max -8 pts for all items listed below)
-Tow strap, -D-ring, Pull Pal, sand ladder, hitch, opening doors and hood, spare tire mount, etc. -1 each.
-Headlights(2) and taillights(2) -2
-Winch -2 front, -2 rear (max -4)
-Full size spare tire. -3
Course points and penalties
Progress: -2 points
Back up/reverse: +1 point
Gate marker: +10 points
Rollover: +5 points
Boundary Marker: +10 points
Vehicle touch (repair & repositions): +10 points
Course direction: +10 points
Winch: +3 points
Assisted recovery: +10 points
Dig/rear steer: +5 points
Did not finish (or point out): point out or high score on course +20 points
Did not start: Point out or high score on course +50 points
Safety Time out
Vehicle out of Spec
-Progress: (-2 progress point) shall be awarded to drivers for each gate that is cleared by the vehicle during the attempt of a course. A gate is considered cleared and a progress bonus shall be given when at least one front and one rear tire passes completely through the gate in the intended direction of the gate. All tires must pass completely through the gate to receive the progress bonus without a gate penalty. A 10 point gate penalty shall be given if all tires do not clear the gate, even if no gate marker is touched or straddled. The tires of the vehicle must travel completely through the gate, and not just break the plane of the gate. Tires must pass through the gate in the same direction and in the same attempt before a progress bonus is awarded. These points are deducted from the total course score. Once a driver has pointed out, no further progress points will be awarded.
-Back up/reverse: (+1 pt) point is given when a vehicle reverses course after making forward progress. Reversing is defined as at any time if any of the tires move the vehicle backward or spin in the reverse direction, whether engaged or in freewheel and/or whether intentional or not. Once a reverse penalty is given, no further reverse penalty can be given until the vehicle makes forward progress. No penalty is given if the backward movement is part of a penalized rollover. If a driver begins a course in reverse, a reverse penalty will occur immediately.
-Gate marker: (+10 pts each) each gate will be comprised of 2 gate markers. Points are given when all wheels do not travel between gate markers or any part of the vehicle, a tow strap or winch line touches a gate marker. A gate marker will remain "live" for the entire duration of the attempt on the course. Once any gate marker has been touched or straddled, no more penalties will be given for that gate marker. Only when a gate penalty is assessed will that gate marker be deemed "dead". No further penalties will be assessed at this point for that gate marker. There will no longer be a penalty for stepping on a gate (for safety reasons) but please stay off course as much as possible and limit course damage.
-Rollover: (+5pts) Points are given when a vehicle rolls over and cannot be corrected without touching. Once the vehicle has stopped it may be rolled back onto it's wheels and a +5 point penalty shall be given. Vehicles that land back on their wheels without assistance are not penalized. No reverse penalties will be awarded until the vehicle is righted. The vehicle may at no time be lifted, slid or moved in any way other than a smooth, continuous roll to the left or right side only. Any other manipulation or movement of the vehicle will be considered a "vehicle touch" penalty.
-Boundary Marker: (+10 pts each) Points are given when any part of the vehicle touches a boundary marker. Once a boundary marker is touched the judge then will stop time, and the vehicle is then moved back by the driver to the previously cleared gate with the rear axle aligned to that gate. If the vehicle cannot be aligned to the gate due to course design, the judge will reposition the vehicle to the next stable location after the cleared gate. This location will be used for all drivers. A boundary marker will remain "live" for the entire duration of the attempt on the course, and should be replaced if moved. Boundary markers are not required in the design of a course.
-Vehicle touch: (+10 pts) All vehicle touches excluding “rollovers”, "winching", "assisted recoveries" (see associated rules) , intentional or unintentional, are given an automatic +10 points. The judge then will stop time when either the driver calls for a vehicle touch or the judge calls a driver touch. The vehicle is then moved back by the driver to the previously cleared gate with the rear axle aligned to that gate. If the vehicle cannot be aligned to the gate due to course design, the judge will reposition the vehicle to the next stable location after the cleared gate. This location will be used for all drivers. Note: All gates for progress are still “live” unless a gate has already been deemed “dead”. Vehicle touches: include but are not limited to: repairs, repositions, vehicle driving/falling into the driver.
-On-course repairs: (+10pts) Must be completed on course and in the spot of which the driver decided to take the repair. Repairs must be made within the course time, while the course timer will continue to run. If repairs are made within the course time, the driver must return to the last previous gate cleared. If repairs cannot be made within the course time, the driver is given a DNF minus progress points for that course. There are no restrictions on whom or how the repairs are made.
-Off-course repairs: (+10pts) A driver can call time to make an off-course repair. Repairs should be completed within 30 minutes, or the driver is given a DNF minus progress points. If the repair is made in the allotted time, the driver must return to the last previous gate cleared. A 1 minute time penalty will be subtracted from the time that is left on that course, the timer will continue once the vehicle makes forward progress.
-Reposition: (+10 pts) The vehicle will be placed with it's rear tires in the last gate progressed or the nearest stable location after the last cleared gate if the last gate cleared is unstable. Course Direction: (+10 pts) Gates must be cleared in their intended direction and sequence. Any part of the vehicle entering an non-cleared gate in the wrong direction, or driven through out of sequence will result in a +10 point penalty. The judge will stop time. The vehicle is then moved back to the previously cleared gate (see reposition rule). Once the gate is cleared and awarded progress it can be traveled in any sequence or direction.
-Winching: (+3 pts each) A winch penalty will be assessed every time the winch cable is connected for a pull. If the winch line comes unhooked during a pull, or a 2nd attachment is needed, another penalty will be assessed. If at any time during the process of removing recovery tools and/or winch line from vehicle, the vehicle is moved by any force other than it's winch or it's own power, a touch penalty will be assessed and the vehicle repositioned to the last cleared gate (see vehicle touch rule).
-Assisted Recovery: (+10 pts) At any time during the course, a driver may call for an assisted recovery. With the clock running, another vehicle will be brought onto the course to pull or winch the stranded vehicle to safety. The stranded vehicle shall not be pulled beyond the original position of the rescuing vehicle or it will result in another assisted recovery penalty.
-Dig/Rear steer (Class 3 only): (+5 pts) Dig and rear steer are both legal in Class 3, but only one may be used per course. The first use of dig or rear steer will incur a +5 point penalty, subsequent uses of the same feature (dig or rear steer) on the same course are free. Use of the other feature is prohibited. If at any time on the same course the driver uses rear steer after using dig, or uses dig after using rear steer, a +10 reposition penalty will be incurred, and the truck will be placed at the last cleared gate.
-DNF (Did Not Finish): (High score or point out +20 pts) are given anytime a driver cannot complete a course for any reason. (Time expired, point-out, vehicle not repairable, went hom, etc) Progress points are awarded for each gate completed and scale points are awarded. **If there is no point out you use the highest score on that course before scale and progress points**
-DNS (Did Not Start): (High score or point out +50 pts) are given anytime a driver cannot start a course for any reason. Vehicle must start course under its own power. No scale points will be awarded to this course.
-Safety time out: A driver may call for time to stop so that he or she may safely reposition themselves on the course. This time shall be used for the purpose of driver safety and may not be used to survey the course or for any other advantage. Once the competitor is repositioned the time will start, however the judge has the right to start time at any point.
-Vehicle out-of-spec: If the Judge has reason to believe a vehicle is out of spec during a course run, he may call time to stop. At that point no additional inputs maybe given by the driver to the vehicle via touch or radio control. The Judge must mark the vehicle’s location and perform a tech inspection in the specified tech area (same manner as all other tech inspections). If the vehicle has been deemed within spec, the driver and vehicle will return to the location marked by the judge and the clock will start once again. If the vehicle is now out of spec and the Judge has determined that the vehicle has gained an advantage, the driver must take a repair to correct the problem. If the problem cannot be corrected to bring the vehicle back within spec, the driver will receive a DNF for that course. If a vehicle falls out of spec due to breakage on course and the judge determines the driver has not gained an advantage, then the driver may be allowed to continue on course without stopping time and requiring a tech inspection. Bodies, and body panels are not included in this exception, and must be replaced immediately, standar
I think Cricket might be easier to understand and has less rules. Anyway, thanks for updating this.
I spent many years with racing organizations and deal with rules. In the end. If you are going to play a game. Make the rules at the beginning so you can spend less time arguing and more time playing. There seem to be two reasons for rules. 1 someone gets hurt.
2 there is THAT GUY. You know what I mean.
New rules out for 2023.
41 pages and things are very specific now. This is no surprise to anyone. As these competitions get more involved and technology evolves a lot of gray areas develop. And it becomes a question of “ the rules don’t say you can’t do something”. And after a while it becomes unbalanced. So read the rules and make your rig fit the rules and have fun.
https://drive.google.com/file/d/1wY...UzbxWV4fFIjWfbuGYVEkAhu3VC9XnzNMzH8rcdQ87zK8U
Access is locked down on this.
