KbigO69
.15 I think
Haha, that guy that played in slipknot lol!
.15 I think
Probably somthing this size.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXDAN7&P=7
10mm seems to be around right for that size motor, but you need to measure the carb opening to make sure it will fit.
Uh..
No i dont believe so..
I acutally think you can use alittle nitro fuel though, NOT sure, .
3-in-1 Oil or any light machine oil can be used in place of after-run oil.
WD-40 isn't the best choice because it is bound to make it's way to the one-way bearing and cause it to slip.
Dude. Issues... :\
as long as you burn all the fuel out of the engine there is really no need for it. Well, you do need to store them inside too. Storing the car outside where humidity can get to the engine and the electronics is a big no-no anyways.
Wd-40 does not cause a owb to slip, it cleans them causing them to grab again.
Any oil designed for engines will work in place of aro.
Aro does have some downsides, it does eat o-rings. That is why they recommend you put it in the gp hole and not in the carb.
Only time i bother with aro is if it is going to be more than two weeks between runs.
