ninnon
Remember to break the engine in.Okay so i bought a new piston and sleeve and also a 2 speed ,but i need some cheap decent looking slick tires and rims not shipped from china
https://www.rcplanet.com/Associated_Spoke_Chrome_Mounted_Wheel_Tire_p/asc2407.htm
Will these do?
@ninnon is 100% correct. There is a break in process that MUST be done in order for your motor to run well and provide a good, long service! There are threads about the break in process in this forum... READ THEM, KNOW THEM, FOLLOW THEM!!! Lol, sounded like a clip from Fast Times At Ridgemont High!!!
I thought it was pretty killer... But then again, not my car, not my money!
Yes and no not a fan of the rims but thanks i know i didnt specify on my style but those tires look good i should get those tires thanks for looking-I'm quite picky on rims toohttps://www.rcplanet.com/Associated_Spoke_Chrome_Mounted_Wheel_Tire_p/asc2407.htm
Will these do?
Once you've replaced worn parts, give it a good clean too.View attachment 18295 View attachment 18296 View attachment 18297 View attachment 18297
View attachment 18300 View attachment 18302 plus today or tuesday I'm getting my transmission and throttle return spring
I used a tooth brush in some areas wd40d some stuff and i cleaned my carb with Carb cleaner,any tips on breaking it in it has a new piston sleeve and pistonOnce you've replaced worn parts, give it a good clean too.
Yeah man in so hyped i have a rewind starter so the metal spring exploded took a while to get that back together,i cleaned up the inside real good my bearings where fine i was tripping out when i has a clicking sound when i had turned my fly wheel its common som say i guess.thanksWow! That sleeve looked ugly! I don't imagine the inside looked better! Glad to see it back together (sort of). PLEASE don't forget to do a solid break in period before you go for the high rpms. We are ALL tempted, but gotta go thru the process to get the reliability! Can't wait to see it running! Good luck!
I believe it mentions the heat method here: https://www.rcnitrotalk.com/forum/threads/nitro-rc-beginners-guide.68224/I used a tooth brush in some areas wd40d some stuff and i cleaned my carb with Carb cleaner,any tips on breaking it in it has a new piston sleeve and piston
Thanks guys i have the original instruction manual and blueprint thing.I did break some cup thing and ordered a new one also my pull start spring exploded lastnight pain in the butt to put backtogether.I odered a throttle return spring.I put my traxxas blue tuned pipe.It took a min to get the car started though i controlled the throttle with my hand.i discovered alot of stripped screws my bearings where fine.putting the 2 speed together was intresting but i learned alot I'm not finished yet though...
Looks like this at the moment
Cbaker65 I appreciate your advice it really helped
It sure sounds cooler and louderJust a heads up. Pipes are tuned to work with certain motors (designed for them) and at certain rpm ranges as well. Some on the low side (torque) and others for high rpms. Def experiment with them but keep in mind that your tune will be different when you change them. Also, be sure to check your temps and the overall performance. I agree... The blue pipe looks great with the kit. Just be sure Its performing as well!![]()
