- Great Smoky Mountains
- Crawling
- Scale Builder
- Flying
It's still clean compared to mine!I swear this was clean when I started.
Yes it was!That chassis kit is a helluva' score!
Thanks, gonna try something a little more advanced on this one, at least for me.Excited to see how you paint up that body.
You're not kidding. Bolt holes will line up, but NOT the wheel holes. LOLLookin' good. That particular rim is one of the hardest to line up, most of my others aren't too bad.
Why can't they make those Servo control cables long enough to reach the Rx?!!! I have a kit/tool to make my own Jumpers, but we shouldn't have to!So, some more stuff came in, and I fianlly got some tinkering time, so more progress is being made. Injora 39mm shocks, J Concepts Tusks (more on that later), servo extensions, and 15wt shock oil.
The frame had a small pocket that with a very light amount of filing, fits the new ESC just right and tucks it in tight for mass centralization. And of course cleaned up and secured my wiring.
Everything tucked in just how I wanted it to with a major forward weight balance. Also trimmed my sliders to clear the body.
Now, about those tires. Apparently I should read a little further before snap ordering stuff. Looks like one of those Iceland tundra rigs. LOL New tires on the way. Also, 1.0” beadlocks suck to work on. I did figure out that spraying the tire with some isopropyl alcohol helps greatly to get things to slide together. Still, getting that first bolt to bite into the hub is a PITA. And all being done under a magnifying hood no less cause this stuff is tiny.
It reached the stock electronics fine. They were where my battery is now. But I flipped the trans around for motor forward for weight bias, and added the Injora ESC and my Futaba RX so I could run my 4PLS. Big difference in low speed control/jumpiness/smoothness. And no ESC whine either.Why can't they make those Servo control cables long enough to reach the Rx?!!! I have a kit/tool to make my own Jumpers, but we shouldn't have to!
Yes, I feel better now....![]()
