truggy83
I recently purchased a revo with a Picco .26 red dot engine installed. When I started it up I noticed it was very loud. I looked and saw the exhaust manifold that is on there wasn't screwed to the engine. It was held in place with a spring which hooked on the manifold on two sides and went around the engines cooling head. It appears like alot of exhaust is leaking at this spot as it is not tight. I want to replace this manifold with something else. I see on the picco engine there is 4 bolt holes in which an exhaust manifold can be screwed in. The way it is set up, there is a rear mounted exhaust pipe in the stock location. I was wonder what manifold I could get that is compatible with this Picco engine. Would a standard traxxas 3.3 manifold work? I want it to be able to bolt up snugly and I want to keep the exhaust in the same spot on the rear.
