need help with my tires...
Niffken
Gone - bye bye.
zap ca glue will not work. The tires keep comming off the rims. I glued both the inside and the outside of the rim. I need to glue every other day now. Any suggestions?
Make sure that the rim is extremely clean of all oils and dirt. Then take a fine grain sandpaper and rough up the inside of the bead where you plan on applying the glue. Apply the glue; then set the tire. Make sure you let the glue set up for at least 30 minutes prior to any use of the tires.
What tires and wheels? Are they chrome plated? Did ya remember to scrape the chrome plating off the bead? Did ya wash everything?
Am I asking really annoying questions?????????
If all else fails, try a different CA.
good questions lead to good answers!!!!
