Need Help With Motor and ESC For custom WRC HPI E10
Tstarkey2489
Military Veteran!
Military Veteran
DFW Texas
  1. Racing
  2. Scale Builder
Hey guys I’m new to the forum but here’s what happens when you should just say no but you have been collecting stuff for over a decade.
Right now I’m trying to finish this up but running into an issue with A Motor and ESC combo.
The Issue is the E10 chassis doesn’t allow the use of a pinion gear smaller then 22 due to the motor making contact with the motor mount and then eventually the center drive shaft cup.
So with 22 pinion and a 78 spur max MPH is around 132mph and 37,000 RPMs based on the phone calculator.
So looking for some help on a good ESC and Motor combo for a 3S battery setup that can deal with the spur and pinion limits.
Not looking for go faster then 65/75mph just fun on the dirt and asphalt. The old lepeord combo in it is a lot of fun when it’s not heat stroking out.
I'd run it on 2S
I was thinking about that just don’t have anything else that’s 2S anymore. So I was hoping to maybe go to a 2000Kv setup but I don’t fully understand the KV range in terms of HP vs TQ .
Like lower KV more TQ but less HP kinda thing I build cars for a living so just trying to relate it to something I understand
Basically reduce the KV of the motor to 2/3 of what it currently is, say for example the current motor is 4000KV then 2/3 of 4000KV = 2667KV
Any motor in the 2600KV range will behave similar to running your current motor on 2S
Here's a demo of running my Tamiya BFX on 4S with a 1900KV motor:
Make sure whatever you get that the motor does not have those deep cooling fins in it. That's probably part of your issue right there. You essentially have a 380 sized motor that someone stuffed in to a 540 sized can.
