95ram
So here's the deal. I was going through glow plugs like mad. So I decided to pull the carb off and clean it thinking I'm haveing a lean issue and to check everything over. While I was doing that I figured I'd seal up the rear with some RTV and clean the one way bearing.
Now here's the problem. When I try to start it with the ez start the ez start motor just spins and the motor doesn't turn over. Did I install the bearing wrong??? What did I mess up.
Sorry if this is a stupid question, but I'm new and still learning. These things are fun when they are running. IMO a carbed V8 is easier to tune then these things, but it gives me something to do.
Should also mention this is on a Tmaxx 3.3
