- Coal Creek Canyon Colorado
- Racing
- Crawling
- Thread starter
- #81
There is a light at the end of the tunnel.
Still waiting on some critical components.
And I have yet to start reassembly of the shocks, I should get to that, I have some shock O rings on order as well though. I have everything (I believe) I need sitting here but I wanted to use some of those X shaped O rings.
I have not attached the speed controller to the chassis. I want to make sure everything is done and in place and I can move that speed control fwd or backward to fine tune the weight distribution. Perhaps that's a bit much but then again, why not.
Key components I'm on hold for:
rear long swing arm rods,
Proper size screws for chassis mounting,
those shock O rings.
That might be it.
I bent the wing more properly than it was. (I must have been drunk, high, both, and couldn't follow directions).
I adjusted the steering linkages much better that I had it before. (Not sure what I thinking there.)
Taped up some of the body cracks.
Got the antenna routed and sized correctly.
Before I boxed it up years ago, the body was cracking on both sides back by the shock towers. I recall applying my crack mitigation procedure to it. (Drill holes at the end of the crack so it doesn't continue to grow.) I recall have to do the same thing on my dirt bike fenders. It works.
I have a new body on order, I certainly don't have to wait on that. I ordered a couple of sticker sets for the Ultima Pro, I can use one of those to apply to this body. Until I really looked it over and compared it to the pictures I didn't realize the stickers I have on there are the stock ones, minus all the logo stuff which I left off for some reason. I recall wondering why I wanted to advertise for anybody. Now I just want it to look like it should.
Kind of funny how much more attention to detail I do now that I clearly didn't do when I first built this thing. If I had just bought this and fixed it up I would have been cussing about the crappy craftmanship by the PO. Primarily the steering linkage and the wing. The instructions are clear, why didn't I follow more precisely then? I forgive myself, I was single minded and eager to get it on the track.
I need to determine how many teeth the pinion should be, nice to be thinking along those lines.
That might be it.
