Had a nice trip to visit our granddaughter in Alamogordo NM. In the back of my mind was the shock issue still awaiting resolution sitting back at home waiting on me.
Well for crying out loud. After much hashing over my stiff shock business I just figured it out.
Not mentioned before but I also ran into the sticky shock issue with one of the front shocks.
I polished the heck out of the shock shaft as well as the inner shock body. Checked and rechecked everything. I swapped components between them and one of each front and rear remained stiff. Swapped out all rubber O rings. Ran the shock shaft through each of the spacers and felt no difference in resistance.
I got to the point I was going to give up on these shocks for actual use and just have them set up for display only. I was about to research a good replacement. I also considered drilling out the small hole the shaft goes through thinking perhaps that was the issue, what did I really have to loose anyway?
Then it came to me as I was doing my final ponder, What if that white spacer was the problem? Even though I ran the shock shaft through it and none offered resistance, what if it was actually swollen so that when I put it in the shock it then caused the resistance?
I pulled out the white spacer, chucked it up in a drill and lightly sanded down the outside of it. That was it! It now installed easier but more importantly, when installed the sticky operation was gone. Worked the same on both sticky shocks! Good grief, that took way too long but at least I got it done. Apparently they were swollen enough that they pinched on the shock shaft only when inserted in the shock body.
In hindsight, there were two shocks that were full of oil when I disassembled them. They were soaked in that oil for 38 years. I'm just glad it is resolved.
Still waiting for my axles to arrive from Japan.
About to wrap up the shock assembly, just giving them a little time to bleed any air out of the oil. I find it amazing that they actually have a device to stick a shock in to that will draw a vacuum and help remove all entrained air from they shock oil. I don't think I'll buy one but it heightens the importance to give adequate time for the air to come out on it's own after a fair amount of cycling.
Onward...
I do have a lot of slop in the front wheels I would like to make better, I've shimmed all things shimable I believe. I think I need to replace the hubs and knuckles.
I could paint up a new body but my sticker sets I ordered are missing in action. USPS says they were delivered but apparently not to me.
Sure would like to get this wrapped up, There is a vintage race at the track in mid July, would love to participate.
