I used 5.8mm balls because thats Kyosho stock on the Optima Mid. LA43H rod ends made a huge difference in smoothness for me.
W201H hardened 5.8mm ball were the other half of the magic.
The 'H' indicates harder materials.
I also switched to titanium ball studs in a few spots, mostly just to save weight tho.
I have never had good luck with those metal rod ends like the ones from Yeah Racing.
Those might be better for crawling.
Its been a while since I've been to the track but no one was running that style end.
I believe the Ultima uses a combination of 4.8mm and 5.8mm balls and cups in the later versions but I THINK yours are mostly 5.8mm
There are hardened versions of all the 4.8mm parts too in case thats the size you need.
Check the links on rcscrapyard for Ultima optional parts lists.
I found optional parts info for the Optima Mid there. It made finding the correct length rods and identifying a few other parts very easy.
Your Andy's arms may be wider than stock.
Andy's arms for Mid are same length.
I replaced my threaded rod with titanium because it was lighter and for ease of adjustment. My car had NO turnbucles.
If you like the turnbuckle you have, if they aren't bent, theres nothing wrong with keeping yours to reuse.
My old cars used dog bones instead of CVAs... HUGE difference there too if you're after 'smooth'. There is NO binding!
They are also lighter so less rotating mass was an easy sell for me!
Avidrc.com hybrid bearings might require more maintenance over time but they are 1000% smoother, they glide vs a standard steel bearing.
I did not think there could be such a difference in bearings.
I was wrong.
It you want smooth, for the price, I think you'll be blown away!!! I don't think you can buy more 'smooth' unless maybe with full ceramic bearings.
I would remove the control arm hinge pins and polish them with Mother's Aluminum and Mag wheel polish before reassembly, use shims to remove front to rear 'play' movement from the arms.
Shimming made a massive difference. Made the car go from feeling worn out and flimsy to tight and tough.
If your old buggy is worn out like mine was, these changes should make your car feel like a completely different RC.
I used a bit of parafin wax on the threaded rod threads as well as in the ball ends as a bit of 'dry lube'.
It seems to be helpful too.
Hopefully that will keep you busy while you wait for your next delivery.
