alien13
I was the project manager for the Speed-NT and was a bit shocked to hear of your problems. We are definitely interested in how/why you have had these problems when thousands of other customers have not. Please advise what you were doing when the metal shaft broke. We did repeated drop tests revving up the engine to top speed and then dropping it on the ground to test the gears. We made several changes to both the material and the tooth profile to get these where they wouldn’t fail after 50+ such successive drops (which should never happen in actual use). What tires where you using? Where you running on dirt or asphalt? What other damage did you find in addition to the broken shaft when this happened. Same for the gears. Did you make any modifications to the model? We are always looking for ways to improve our products but if we can not re-create the problem it is hard if not impossible to see what needs to be done.
I have never heard of a rod breaking in the 3.4 engine during normal use. Did you send the broken engine to Horizon for replacement? We tested these engines with 40% nitro both on the dyno and in the truck at over 38,000 rpm without failure. If there is a material problem we would definitely like to advise the supplier as we spec out 7075 T6 aluminum and are given certs that this is what was delivered. This is far superior to any other small block RTR engine and is what is used in our racing engines. Again if we know more about what the conditions of failure was we can try to re-create them. I assume you did not let the engine free rev without load on it?
You sound like an experienced RC car guy so I assume you have nitro engine experience and any insight you can supply would be most appreciated.
Thanks for bringing this to our attention and your help to figure out why you are having problems.
Best Wishes,
Gary Kyes
Losi
I replied to him telling him pretty much the whole story from when I get the new engine and on. Hopefully, something good will come of this.
Best Wishes,
Gary Kyes
Losi
