My new Shredder wobbles when it runs, but only when going forward.
Yankeedoodle30
Pismo Beach, CA
My Shredder slightly wobbles when it runs, but only when it is going forward. In reverse, it's runs smooth and tracks straight (without a gyro installed) My question is: Does a brushless motor go as fast in reverse as it does in forward gear? Are the torque curves the same when the motor runs backwards? Does the ESC care which direction the motor is rotating?
look at rims and dents bumps..also check hexs on axles for pins . turn main drive shaft and look at axles..bearing so on check all if you have to
Everything looks good. no dents, bumps, axels are perfect, drive shaft fine, no run out, runs perfect backwards. Has anyone every driven and steered an R/C vehicle using read tires?
rear steer yes.. I have a clod buster custom setup with only rear steer.
