This is my Team Associated B74.1 Team Kit my dad originally bought this buggy kit in Spring 2021 and then sold it to me for $500 in Summer 2021. It has been my only race vehicle since my old TLR 22T 4.0 and it's been a good reliable buggy. It's also my oldest vehicle had it again since Summer 2021 and it's almost exclusively run at my local carpet track in Oklahoma City, OK called 405 R\C Raceway.
Specs.
Hobbywing Xerun XR10 Justock G1 Sensored Brushless ESC
Unknown brand 5mm bullet connectors soldered onto the ESC
Reedy S Plus 13.5 Turn Sensored Brushless Motor
Team Losi Racing 29 Tooth 48P Aluminum Pinion gear with 3.175mm bore meshed to a Team Associated 72 Tooth 48P plastic Spur gear with octo lock slipper clutch system
Spektrum DX6C 6 Channel DSMR Computer 2.4Ghz Transmitter bound to a Spektrum SR315 3 Channel DSMR 2.4Ghz Receiver (Current radio system), (I used to run this car on both my old Futaba T4PM TX with an T-FHSS SR RX and my old Radiolink RC8X TX with an R6FG RX. I have plans to eventually move up to an iXSR and run the SR315 at 5.5ms frame rate)
Savox SB-2263MG-CE Low profile metal gear high speed digital steering servo
Pro-Tek RC 2S 7.6V 4,600Mah 120C Lipo-HV Battery and an SMC Graphine V2 Extreme 2S 7.4V 4,100Mah 120C Lipo Battery both with 5mm bullet inputs
Team Associated stock metal gear front and rear differentials with kit fluids
Team Associated aluminum 12mm bore shocks with stock kit fluids
Schumacher white dish wheels mounted to Cactus fusion 4WD tires front and Cactus 2.2" Rear
Team Associated B74 stock body custom painted in dark blue metallic
Here's some pics.
Here she was when i first got her. Not much has changed.
Specs.
Here's some pics.
- RC Type
- Car
- RC Brand
- Team Associated
- RC Model
- B74.1 Team Kit
- RC Scale
- 1/10 Scale
- Power Source
- Electric
- Battery Type
- LiPo
- Motor Type
- Brushless
- Drive System
- 4WD (Four-Wheel Drive)
- Budget
- $800-999
